Supercharger Kit For an FE??
  • Thread starter Thread starter Kevin Murphy
  • Start date Start date Apr 24, 2007
K
Kevin Murphy
12
Danville, CA
Apr 24, 2007
  • Apr 24, 2007
I have been looking around and can not seem to find any centrifugal superchager kits that are available for a big block FE. I have seen some BBC kits available but no BBFs. Does anyone know of any custom kits that are made anywhere? Any help would be appreciated.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Apr 24, 2007
  • Apr 24, 2007
I've never seen any myself. To be honest, the only difference between most of these kits is the SC mounting brackets. You will probably have to take the car/engine to someone who can build you a set of custom brackets.
iskwezm
4,159
20
79
Rowland Heights,California
Apr 24, 2007
  • Apr 24, 2007
Try The Dyno SHop in Santee,Ca. I saw a Fairlane(i think) with a 427 and Vortech, looked great and sounded even better.I'll get a pic up tomorrow.
PoliceInterceptor
Keeper Of Automotive Oddities
2,161
Live in GA, But could be any where really.
Apr 29, 2007
  • Apr 29, 2007
Try these Guys.
http://www.cobraautomotive.com/horsepower.htm
Take money....
67FBack
316
New Braunfels, TX
Apr 29, 2007
  • Apr 29, 2007
Kevin Murphy said:
I have been looking around and can not seem to find any centrifugal supercharger kits that are available for a big block FE. I have seen some BBC kits available but no BBFs. Does anyone know of any custom kits that are made anywhere? Any help would be appreciated.
427FE Pulley system and super charger brackets made by Concept One: (Cheesy blue hose is only temporary)
You have to call them and ask about the Super Charger "Eleanor " kit.
K
Kevin Murphy
12
Danville, CA
Apr 29, 2007
  • Apr 29, 2007
Thanks for all the leads I have been searching and having no luck till now
67FBack
316
New Braunfels, TX
Apr 30, 2007
  • Apr 30, 2007
Me too. I looked everywhere. Not many people are doing FE's with S/C. Very expensive.
1320stang
4,329
23
89
Edmond, Oklahoma
Apr 30, 2007
  • Apr 30, 2007
Jay Brown on the FordFE.com forum has a Procharger on a FE.
Jay won the 2005 Hot Rod Drag Week in the BB N/A catagory with his '69 Mach I.
He was supposed to do the Procharged FE but all the kinks weren't worked out.
Jay then won the 2006 Hot Rod Drag Week in the SB P/A catagory with his 2005 Ford GT. Again, he had made some changes and the engine wasn't done.
I don't know what Jay is entering this year but he has had a SOHC 427 Cammer FE (I don't know how else to say it's a 40+ year old engine and not a late model stroker or a mod motor) on the engine dyno in the chicken coop in his barn. He has been testing intakes on 428's and done exhaust manifold/header tests on the 428 engine as well.
Most of the books out there on the FE have a lot of bad information in them. The FordFE.com site is the most definative site you can find info for the FE. We're hoping that in the next couple of years Jay Brown and Dave Shoe (Schouweiler) will write a book on the FE.
67FBack
316
New Braunfels, TX
Apr 30, 2007
  • Apr 30, 2007
I was reading some of Jays post. A lot of good info on supercharging, etc etc. Doesn't he have his own dyno?
1320stang
4,329
23
89
Edmond, Oklahoma
Apr 30, 2007
#10
  • Apr 30, 2007
  • #10
LOL!! Re-read my 4th paragraph.
Yes, he does indeed have his own dyno. Jay is an electrical engineer, he's very technical, but can dumb it down enough for most of the rest of us to understand. If you search 'dyno' or 'results' on the forum, you'll find a ton of threads on his intake and exhaust tests.
bnickel
5,640
lubbock, texas
Apr 30, 2007
#11
  • Apr 30, 2007
  • #11
i believe he also sells bracket kits for the procharger as well, doesn't he?
for some reason i want to say vortech also has an FE kit as well.
67FBack
316
New Braunfels, TX
Apr 30, 2007
#12
  • Apr 30, 2007
  • #12
ha ha .. The chicken coup Dyno!!!
K
Kevin Murphy
12
Danville, CA
Apr 30, 2007
#13
  • Apr 30, 2007
  • #13
67Fback in terms of cost what is a rough estimate to get my 390 supercharged?
67FBack
316
New Braunfels, TX
Apr 30, 2007
#14
  • Apr 30, 2007
  • #14
That is an open ended question. S/C can be done for about $2500-$3500. But....
you really should have a tight (new parts) engine to handle the increased stress on all the components. Also, a lower compression ration (preferably 8.5:1 maybe a little more, I am not the guru). But you start putting more than 12-16 lbs boost, you have to start changing timing, fuel etc etc etc
K
Kevin Murphy
12
Danville, CA
Apr 30, 2007
#15
  • Apr 30, 2007
  • #15
67Fback-
Ok well heres my engine,
http://www.fordcobraengines.com/390_420hpFord.htm,
I didnt buy it for that much I got a 2 years ago and it was about half the price. Take a look and let me know and let me know what you think. Thanks again for the help
iskwezm
4,159
20
79
May 1, 2007
#16
  • May 1, 2007
  • #16
even a lower boost levels like 7-10 psi,colder plugs,timing should be retarded a bit,boost retard,a cam with a wider LS(114+) and fuel pump capable of stock fuel pressure plus 1psi for every 1lb of boost. My pump is capable of 45 psi and 360 GPH as well as -10(1/2") line to the carb.All the "small" stuff can nickle and dime you to death
67FBack
316
New Braunfels, TX
May 1, 2007
#17
  • May 1, 2007
  • #17
You are not kidding about the nickel & dime!
I added the boost referenced pressure regulator. My timing is set at 38 degrees, and I am using the MSD 7530T to retard the timing 1 degree per pound of boost. I have a Ricks Automotive 22 gal tank with an Aeromotive 1000 in tank fuel pump.
And don't forget, HP=heat. So you might add an oil cooler, bigger radiator, stronger fans, after cooler and a cold air intake (from anywhere not in the engine bay).
HP costs $$$$$. How much HP do you want?
iskwezm
4,159
20
79
May 1, 2007
#18
  • May 1, 2007
  • #18
You mean how much can you afford?????
K
Kevin Murphy
12
Danville, CA
May 1, 2007
#19
  • May 1, 2007
  • #19
I'm looking to get round 550 rwhp and a little more torque.
M
Looking for a passenger side AC Compressor mount
  • mustangTodd
  • Feb 10, 2026
Classic Mustang Specific Tech Aug 22, 2026
s_mi11er
C
Fox Need help identifying brake setup
  • Cypher02xd
  • Apr 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
Mustang5L5
Looking for a high-res photo or scan of Rotunda EEC-IV Overlay #17 or #23
  • Smokinjoe 33
  • Jul 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 21, 2026
Praetorious
P
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
