supercharger or nitrous on a oil burning motor?
Well I was thinking about putting either a 100 shot or 6 psi on my motor until it lets go. How much faster do you think (if at all) the engine will die. And after I rebuild the motor what is a safe supercharger nitrous combo I was thinking 8 PSI with a 50 shot for an extra kick but wasent sure. All forged internals will be used on the rebuild on the stock block. Thanks alot guys. :flag:
if you plan to blow it sky-high, just slap a 150 shot on it, and go for broke...
but if you're going to assemble a new engine, honestly, its a waste of time, money, and weight to install a forged crank into a stock block...the crank would handle more than the block could...
a good cast steel crank from Scat, or Eagle would serve you well, and be alot less expensive (about $200 for a new crank), same goes for the rods, also about $200 a set for Scat forged I-beams...you can have fun with the pistons though, get a set of Probes, or something of that ilk, and you'll be set...until the block gives way
the part prices I'm quoting are from
www.cnc-motorsports.com
they have some great prices, and good availability. I squared away a Scat 331 crank, Scat 4340 I-beam cap screw rods, and probe dished pistons with total seal conventional rings from them for $900, the only thing I had to get to finish up the internals was the bearings. the other parts, like the oil pump, oil pump driveshaft, gaskets, and such will be purchased at a later date, but for what I paid, I think I got a good deal
