mogs01gt said:No reason to lock. Lets see why they are say they are right. So far they have no proof other than their opinions.
No, now you are trying to change what I am saying to fit your side. This entire thread was about which type performs better. Not one person has brought up anything that makes a positive displacement blower, like a Kenne bell, out perform a Centrifugal. Everyone is saying, take the gears out, same boost blah blah blah. If you guys really want me to find more articles and websites that say the same thing about a high peak torque compared to a lower peak torque is better for accleration, fine I will. I know there are a lot out there. I have read them.Then you people will try and make the same arguments about gears,same power levels or blah blah. When you race a car, you build it to what you have. Last time I checked, people do not just slap on parts that do not help performance when they want performance.mrpositraction said:Where does horsepower come from? It comes from torque and rpms.
If you take the same car (same, gears, engine type etc.) and put a 6 psi twin screw or a 6 psi centrifugal, the twin screw makes more power early, which will make it accelerate early. And what facts have you pointed out. You say, this car with gears, the article states. These are not facts, these are your own personal facts that you have justified in your mind. Think about what you are saying. The car that makes boost (power) later will win a race, it just doesn't add up. If we were to race 1/8 mile, 1/4 mile, or cross country, having the torque down low (horse power down low) it only makes sense who would win. Now when you start to say that changing gears in the centri and then race, well then we are comparing two different cars. I make 6 psi at 2000 rpms, I have read countless forums (not facts, facts are results from a controlled study, not my buddy said) about guys having the rev limiter set higher (I think it might be in this thread of moving it to 6800 rpms, again another modification to the car, not the same car) to get full boost or a little more. I have 6 psi from 2000 - 6000 (or until I blow it up), positive displacement works different than centrifugal, it does not depend on rpms ( after 2000) to make boost. I don't trackl my car, it is a daily driver and I love feeling the power at all rpms (even at 1000 I can see 3 psi, you can't say that about your 6 psi centri kit). In the end, your argument just doesn't make sense, and be careful what you call facts.![]()
supras now?? What does supras have to do with a Modular mustang with forced induction??WhiteDevil69 said:If it will end this useless debate then your right mogs... torque isn't important for acceleration.... Thats why supras with 1000hp are running 12's... Unsubscribing, waste of time, thickest head I have ever encountered.![]()
P.S. I will give it to yah though, you never give up..![]()
mogs01gt said:Until any of you can prove me wrong, my statements are all true. You guys havent come up with any facts or truths. You have only posted your opinions.
read the article over. It states clearly that the 3000 and 6000 rpms, is the peak torque ratings for each motor. Not the max the motor car spin at.
This is why I brought up the supra's. You cant make statements like this and not expect someone to correct you... this just doesn't make any sense, I mean, do you really believe this?mogs01gt said:Well that is fine, you can go ahead and be wrong but low end torque is not needed for acceleration.
My point was, motors do not need to make peak torque at a low RPM to have accerlation.WhiteDevil69 said:This is why I brought up the supra's. You cant make statements like this and not expect someone to correct you... this just doesn't make any sense, I mean, do you really believe this?![]()
mogs01gt said:No, now you are trying to change what I am saying to fit your side. This entire thread was about which type performs better. Not one person has brought up anything that makes a positive displacement blower, like a Kenne bell, out perform a Centrifugal. Everyone is saying, take the gears out, same boost blah blah blah. If you guys really want me to find more articles and websites that say the same thing about a high peak torque compared to a lower peak torque is better for accleration, fine I will. I know there are a lot out there. I have read them.Then you people will try and make the same arguments about gears,same power levels or blah blah. When you race a car, you build it to what you have. Last time I checked, people do not just slap on parts that do not help performance when they want performance.
Find me some modulars SOHC with a Kenne Bell that is running 9s or 10s.
oh my God) THUNDERBIRD!
mogs01gt said:the slow reving part was referring to the shorter gears. Not comparing the motor without gears to each other.
Not sure where you get this 3.5psi at 3k. Most Centrifugal blown cars I have seen, reach peak boost levels between 3k and 3.5k rpm. Not 3.5psi.
My friends stock lt1(has a catback), whom I usually race at the track because he cant drive. will see 6psi, max boost, at around 3k at WOT. PSI is also a measurement of pressure, without a device to measure the actual air flow, I cant comment on which type will flow more air into the motor at a comparable psi.
Turbo's is a whole other discussion.
I was just going to use that example….mogs01gt said:swweet, what are the stats on it. What is a AED? Allen supercharger?
ohh and I love how all these newbies always put OWNED in their threads. whoo OWNDED, hoho wow OWNED.
Gearbanger 101 said:I was just going to use that example….
Mike Siska runs a ’95 Thunderbird that weighs in at over 4100lbs with him in it. If memory serves he's got ported PI heads, 4.10 gears, full exhaust and a 3200 stall in a built 4R70W.
He runs 10.90@128mph on 12psi. The charger is an intercooled Lysholm 2300AX twin screw (similar to that of a KB) and make around 525-550rwhp.
You can actually see his car in one of the last couple of issues in MM&FF in the Luxobarge shoot out.
Given all things equal mogs....would you still think that a centi would outrun a positive displacement blown car? Say 6psi (Centrifugal blower of your choice) VS. A 6psi KB Car. No gear changes, no weight reduction, nothing at all different.....both running D/R's, who's got the advantage?
Sorry....just wanted to let things unfold a little further. You just can't change some peoples mind no matter how much tech and fact you present. Regardless how much you throw at them, theirs is always better.prsrizdgt said:Bout time you showed up. I think this is over though....besides the guy is brain dead.
That being said, if you go over to the TCCOA site and talk to some of the guy running the Vortech's on their cars, they'll tell you that although it's a nice jump in performance, they don't move like they thought they would. And the ones that are getting them to go half decently at all have to gear them and run high stall set ups just to be on par with the AED guys. Just too damn much weight to move I suppose.
I guess that's why all of the bigger (heavier) vehicles (Cobra, Lightning, Top fuel Cars) use the positive displacement. The Centi's just don't move enough air on the bottom end to sustain their CID, or their needs.Laser-01-gt said:http://mustang50magazine.com/techarticles/138_0404_open_dyno_s.jpg
http://www.kennebell.net/media/articles/2_SCREW.pdf
here are links to 2 different magazines testing 2 different 4.6. I know it is hard to figure out, but please look close at it all.
link one shows a Mach 1 with a vortech, and a peak hp of 351.3@6000 rpm
link two shows a GT with a Kenne Bell, and a peak hp of 350.8@6000rpm
we could not get closer if we tried, a net differene of 1/2 HP. at the same high rpm.
but look at the torque numbers on both, the KB is making over 350ft/lbs from 2500 to about 4700rpm. while the vrotech is doing exactly what we expect, gaining power as speed climbs. at 2500rpm it only makes 216ft,lbs.
that equates to 166hp vs 103hp at 2500rpm better by 63hp
by 4500rpm it is 300hp vs 264hp better by 36hp
by 5500rpm it is 345hp vs 337hp better by 8hp
and even at 6000rpm
i dont car what you say, you need to pass 4000rpm and 5000rpm before you get to 6000rpm.
before someone says something about diffent engines on different days on different dynos. no dyno is going to be off by over 130ft/lbs at 2500rpm
Nice, yah, i think that was the proof he wanted to see. I guess we have detemined that it really depends on your whole setup rather than just which blower is better..prsrizdgt said:Well put my friend......makes a nice end to this thread I think.
