Not everyone wants to run 4.30 gears in their car to make up the difference though. Like I said, most stock cars with Centrifugal chargers that I have seen are usually dyno queens. Meaning they make lots of power on paper, but can't transfer it to the pavement.
If low-end torque isn't a big deal, for comparison, why do the old 2.73 geared 5.0L's run so close to the 99-up 3.27 geared 4.6's in stock trim? And don't come back with the weight difference excuse, because a couple of hundred pounds are only good for a tenth or two. Sure the later model SOHC 4.6L actually peaks a little higher than the OVH 5.0L, but the 5.0L comes in nearly 1000rpm lower and shows it at the track!
