Ok, I searched and never found exactly what i was looking for so here it is. I have a fox short block with forged stock pistons. the block have never been decked, .40 head gaskets, edelbrock aluminum heads 170cc, edelbrock upper and lower/intake and elbow, 75mm throttle body, stock rails with 30lbers, and a matching maf, fmu for the same, crane cam (don't have specs handy right now) with 1.7 rr's, long tubes, off road x pipe and cat back, adjustable reg. Msd btm, vortech v1 s trim with a 3.33 pulley and an anderson power pipe. might be forgetting some things here but if you need more ask.
So her are some of my questions. I have a 255 lph in tank pump. do you think I need the t rex?
What fuel pressure should I run?
What base timing should i run? i know I am going to run the spout in I don't want to lock my timing out.
Also what should i run on the btm
OK i have a 6al box in the car now, ditch it or can I run them together?
keep in mind I am just trying to find a starting point till I get to the dyno shop. thanks for the help.
