  • SN95 4.6L Mustang Tech
supercharger with high compression????
  • Thread starter Thread starter 98blackstallion
  • Start date Start date Dec 27, 2006
98blackstallion
602
mtn home arkansas
Dec 27, 2006
  • Dec 27, 2006
hey guys is there anyway to supercharge a car that has 11.2:1 compression? Just kinda curious if i could or not..Thanks guys because i can get a supercharger kit for cheap and if need be then i can replace the head gaskets with thicker ones and have the combustion chambers milled to help lower the Cr???
NitroFishGT
  • Dec 27, 2006
Of course you could put it on, but you'd be wasting your time and money. You would only safely be able to run like 3 lbs of boost and probably race gas. With high compression I'd lean more towards nitrous for a power adder.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Dec 27, 2006
  • Dec 27, 2006
sure you can. just make sure that your internals are super strong. o and you will have to run something like VP Racing C16 117octane gas. and your tune must be dead perfect.
98blackstallion
602
mtn home arkansas
Dec 27, 2006
  • Dec 27, 2006
see this is my daily driver and as it stands now i have to run 93 octane.
speedytang
765
Marengo,Ohio,US
Dec 27, 2006
  • Dec 27, 2006
Supercharger and that compression and 93 octane will not happen with a tune or not. I have done this before on cars and by the time you removing timing and plugs fowling all the time you make the same horspower without the blower as with. Supercharger'Pressure' is raising your compression that is the way it works so with 5psi you will be at 13-1 compression and so you will need Octane for that compression.
T
thomas91169
I'd donkey punch my sister.
Aug 19, 2005
Modesto, CA
Dec 27, 2006
  • Dec 27, 2006
yeah no, not at that compression. If it was in the low 10 range id say possible with awesome tuning at around 6-8psi, provided you get 0 knock, and are running on the rich side for safety purposes, and a EGT and wideband o2 Gauge were installed so you can keep track of things in realtime. youd be suprised how much a change in the barometric pressure or temps affect a tune, it can be rich one day and lean the other.
a Evo has a cr of 9.5:1 on stock semi-forged rotating assembly and can run 28psi safely. A local rebuild his to 10:1 fully forged and runs 15psi safely, and found his edge when he tried doing 20psi on racegas and had to shut down half track cause his EGT's shot up the roof and his knock sensor went crazy. at 17psi he was able to run with racegas and not get knock.
Stan Weiss
347
Philadelphia, PA
Dec 27, 2006
  • Dec 27, 2006
Will you be running an inter cooler? Will you be running water / alcohol injection? Both of these will reduce the temperature increase from the blower. If you want to run high boost levels convert to E85. Also are running the stock camshaft?
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
Engine Felpro 9333 pt1 (with 8psi boost)
  • JD1964
  • Jan 14, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
Qtrhrse23
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
For Sale 1987-1993 (Foxbody) Procharger D1SC Supercharger Kit
  • 89Daley
  • Aug 3, 2025
  • Engine and Power Adder
Engine and Power Adder Oct 12, 2025
1fas89ssp
