  • 1994 - 1995 Specific Tech
Supercharger
  • Thread starter Thread starter 94RIO
  • Start date Start date Jun 8, 2004
9
94RIO
  • Jun 8, 2004
I have a 94 GT 5-spd w/373 gears, flowmaster 2 chambers,and a mac h-pipe. I want to add some power, what kind of supercharger and shorty headers would you run. How much boost is safe on a stock motor? What HP and performance can I expect to see with these items?
CManT1914
3,172
Killeen, Texas
Jun 8, 2004
  • Jun 8, 2004
I'm not gonna tell you what kind of supercharger to get, it will just start a "this is better than that" war. I would go with a Procharger P-1SC, but that's just me. On a stock motor, only run between 6-9 lbs. of boost. Slap some BBK longtubes on there, and it should haul.
EDIT: Running 9 lbs. of boost, you should be looking at about 350+ horsepower. At least, that's what I've read. About 14 HP per pound of boost.
94TURBO5 O
2,509
VA
Jun 8, 2004
  • Jun 8, 2004
I am completely stock and I have an S-Trim w/ 12# pulley and I dyno @ 392/420 that was pushing only 4 degrees timing and ~9-10 #'s. Technically they say 14 #'s will blow your chit and I am not going that high w/ 160K on the block. I just replaced head gaskets from detination this past week so get a good tune. A blower should give you 100hp straight up with stock motor with a Vortech. I dyno 328/378 with the the 3.33 pulley (stock w/ Vortech). Before the blower I was at 225/280 with bolt-ons.
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Jun 8, 2004
  • Jun 8, 2004
Paxton, Vortech, or Procharger. NOT POWERDYNE!
Im sure you can find a used Vortech with all the guys looking to upgrade to Turbo! I run 8-10lbs of boost. I would at least do a MAM (with better injectors), TB, and Intake upgrade with that, along with Elec fuel pump. With the above, your mods and stock heads, you should make it to 370+ to the wheels.
With you current mods, Vortech, and stock everything else, you could see 340-350.
RC
Venom351R
4,548
41
98
MAINE
Jun 8, 2004
  • Jun 8, 2004
Im running a Paxton Novi 2000. Ive had it on for about a month and so far a I love the damn thing and I havent even had it up to full boost yet. My clutch slips past 5-6 PSI or 4000 RPMs. Were putting in my Spec II clutch tomorrow and thus and were all going to the dyno on Saturday. Im hoping to pull between 330-350 w/ my current mods running 8-10 LBS of boost. Look for my thead on saturday night to see my dyno results.
PS: Im running #30 Injectors w/ the FMU.
Venom351R
4,548
41
98
MAINE
Jun 9, 2004
  • Jun 9, 2004
damn thats a good refrence point for me. So let me get this stright. Before your Vortech you were putting down 225/280 N/A. W/ the Stock S Trim Pully you put down 328/378 and w/ the pully upgrade to a #12 pullly you put down 392/420? Im only asking b/c a bunch of us are going to the dyno in Concord N.H on saturday. Im just racking my brain at what I will put down. Before the paxton I was putting down 231/285. Im hoping to pull about 8 PSI on the stock pully and put down between 330-350. Only thing Im concerned about is that there is this "Recucer" that is located past the mass air meter and it cuts down on the amount of air the S/C gets. I dont know why Paxton put this in the kit but all it does is cut down on the amount of air the S/C gets and prob cuts down on boost. W/ the stock set up you have to use it or the Mass air meter wont hook up, once I get a power pipe or make my own out of PVC pipe then I can take it out. One guy said he went from 8 PSI to 12 by taking the reducer out.
94TURBO5 O
2,509
VA
Jun 9, 2004
  • Jun 9, 2004
That is correct and you should gain at a minimun 90 hp with your set-up IMO. I have a AFM pp and I have heard it is supposed to raise the boost 3 #'s from that alone but I never really look at the gauge when I am @ WOT. Good Luck this weekend on the dyno and let us know the results.
Venom351R
4,548
41
98
MAINE
Jun 9, 2004
  • Jun 9, 2004
I had a AFM PP but it wont fit w/ a paxton b/c it sits back futher then the vortech and it wont clear the strut tower. Im looking at getting the UPR Power pipe. I'll be sure to post my #'s when I get back home sat night. The closer I get to 350 the more I'll be but I really just want to break 330 for now. If I can do that w/ out any type of power pipe w/ that reducer in there then I'll know I can unlock alot more HP and PSI once I get that out.
YEAHLOH95
1,249
EVERETT,PA
Jun 9, 2004
  • Jun 9, 2004
i know i'm not running stock heads like you guys but i am running a power pipe and i saw 10lbs with the stock pulley and with a 2.95 i'm seeing 15 now when the belt is tight thats all on a stock bottom end . on another note you might want to put some miles on that clutch before you go get dynoed they need at least 500 street miles before you get on the dyno a guy i know with a 03 cobra tried dynoing after a new clutch install and the gragh was all over the place cause the clutch wasn't seated properly .
94GTLaserRC
11,178
Jun 9, 2004
#10
  • Jun 9, 2004
  • #10
94SC50 said:
I am completely stock and I have an S-Trim w/ 12# pulley Before the blower I was at 225/280 with bolt-ons.
94TURBO5 O
2,509
VA
Jun 9, 2004
#11
  • Jun 9, 2004
  • #11
What now? I mean stock being heads and bottom.
94GTLaserRC
11,178
Jun 9, 2004
#12
  • Jun 9, 2004
  • #12
Oh, cause your statement said "completely stock"
I was a little
RC
94TURBO5 O
2,509
VA
Jun 9, 2004
#13
  • Jun 9, 2004
  • #13
94RIO was asking how much boost was safe on a stock motor.
Venom351R
4,548
41
98
MAINE
Jun 9, 2004
#14
  • Jun 9, 2004
  • #14
Yeah I know, luckly we got it all done today so we wont have to do it tomorrow, need to put on alot of miles between now and saturday
raven69david
112
San Antonio, Texas
Jun 9, 2004
#15
  • Jun 9, 2004
  • #15
Was this on a GT or Cobra? Check out my sig....i'm wondering what i will dyno?!
GoBabyVroommm
1,156
Chicago, For Realss???!!!
Jun 9, 2004
#16
  • Jun 9, 2004
  • #16
I want a pro charger. I like that blow off valve or whatever you call it. Its soo kool!!! But yea besides that its a really good blower. I heard prochargers are the way to go if you have a stang.
94TURBO5 O
2,509
VA
Jun 10, 2004
#17
  • Jun 10, 2004
  • #17
GT motor and when I say stock I mean heads, cam and bottom. I have a Cobra intake on all 3 different dyno #'s.
I say you will capable of at least 375 or 400 depending on your boost and timing.
R
rapidsft
37
San Jose
Jun 10, 2004
#18
  • Jun 10, 2004
  • #18
Procharger D1-b
I ran a Procharger D1-b for 2 years on a Stock motor. I hit 14-15p.s.i and it ran great. I had to retard the timing down to 3degrees. I never had good traction at the strip, however I hit a 13.000@111 with a best 2.01 60ft time. It had a bullet 73mm mass air meter, 24lb injectors 3.55gears and a bbk offroad pipe. Everything else drivetrain related was completely stock. After 2 years of running 14-15p.s.i the piston rings started to wear. I eventually had blowbye comming out my dipstick tube and breather from my valve covers. I ran 92octane pump gas all day everyday, except when it was freezing cold I used 87octane. Any questions let me know.
Venom351R
4,548
41
98
MAINE
Jun 10, 2004
#19
  • Jun 10, 2004
  • #19
yeah the head units go right back to prochager once they start to leak I was going to go w/ a Procharger but while I was saving up my money for one I read a thread in the 4.6 section from some guy who just put a P1SC on his and 500 miles later the head unit was leaking. From what I hear procharger had fixed the problems of there leaky head units. Some people never had any probs and some people had constant problems. I think alot of it was due to people over filling the head units although they swear up and down they dident . But either way that one thread turned me off from PC b/c I wasnet going to throw down over 3K for a blower and spend all summer sending the head unit back so I went w/ Paxton and Im gald I did, what a nice unit and from what I hear the ( and have seen from mine so far ) the Novi 2000 is one hell of a blower. I'll find out just how good it is once I get it dynoed.
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
E
1986 Convertable 5.0 GT
  • eneerg
  • Sep 24, 2025
  • The Welcome Wagon
The Welcome Wagon Sep 24, 2025
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
