supercharger
yea im gonna say you should forge it out first also. with the heads and cams you will be making more power then a stock car with the 1.7. kb says its safe on a stock car.
lgndracer said:
You have a 1.7 IC 11lb, heads and cams and are only at 439/434? :shrug:
That must be one very conservitive tune. I would think you would be at closer to 475 or so with those added mods.
Those are actually good #s. Plus he has an auto. KB 1.7L really lose its efficiency when you go over 10 PSI. There are some who couldn't top 450rwhp (with a 5-speed) despite running on 14lbs max. Unlike the KB 2.2, the 1.7 wasn't exactly designed to run that much boost.
