Supercharger
Step90
United States
I’m looking into getting the Whipple installed on my 2015 S550..my only concern is what all parts should I get before I even install that on my ride. I’ve already installed springs and I have the proper wheels for it to handle. Do I need a new drive shaft..half shafts..clutch and flywheel..new fuel injection? I just don’t want to install it and my ride not be able to handle the power and something snap
If you want to truly be safe, then swap out the MT-82 trans for the much stronger T-56 magnum XL. A complete trans kit will run you about 6K, but you also get the clutch, bellhousing, and new driveshaft. Another 1500 or so will get a set of 800 hp rated half shafts. Unless you plan on pushing the engine output to 1000 hp or more, then the larger injectors that come with the S/C kit will suffice for the fuel system.
Reactions: Step90
