Surging Idle
  • Thread starter Thread starter slow5.0gt
  • Start date Start date Aug 16, 2006
slow5.0gt
138
  • Aug 16, 2006
Does anyone else have a surging idle upon a cold startup but after 10 mins or so it goes away and idles just fine? I looked in the surging idle checklist but still wasnt clear on what causes that.
It just reminds me of my friends integra that did that on cold days to warm up faster.
D
dude5l
201
Grande Prairie, Alberta , Canada
Aug 16, 2006
  • Aug 16, 2006
Mine does the exact same thing. Once it gets up to temp it seems fine. Iblame it on not having a chip burnt for it yet. What mods do you have?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 16, 2006
  • Aug 16, 2006
Go through the surging idle checklist and fix the things you know need fixing. That includes dumping the codes, fixing the code items and replacing old vaccum lines. At that point, plan on replacing the IAC if you still have a cold start idle problem that didn't clear when you did the neeeded maintenance.
slow5.0gt
138
  • Aug 16, 2006
full boltons,gears,cam ported heads
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
Aug 16, 2006
  • Aug 16, 2006
Mine does that too, and it always surges when the a/c is on. I blame speed density.
HISSIN50
34
129
Aug 16, 2006
  • Aug 16, 2006
79PC, Have you yanked codes lately? On my '88, the only time I got surging was when the IAC decided to go on walkabout and idle-up too high. I was spittin an upper-limit code and it surged with AC on (only).
Just an idea (that I'm sure you checked already).
slow5.0gt
138
  • Aug 17, 2006
A curious thing I found out was that if I raise the fuel pressure the surge lessens/ stops when I lower it the surge comes back.
795.0pacecar
Jul 11, 2003
480
Senoia, GA
Aug 17, 2006
  • Aug 17, 2006
It doesn't thown any codes that matter, all the codes are thermactor codes. Im on my 3rd IAC and 2nd TPS and every other sensor is new. Im converting to mass air in a week, so well see if that helps. My problem could also be that the computer doesn't know when the a/c is on. On the 86+ the HVAC controls connect to the computer, and run through to the pump, on mine that is all bypassed so the HVAC controlls run straight to the compressor.
If I knew which wire to tap into the a/c system from the computer I would.
Supaman
365
Hawaii
Aug 18, 2006
  • Aug 18, 2006
Check your distributor. If the armature gets in contact with the stator, it could be causing your trouble.
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
9
Electrical F150 ECU in a Foxbody? Idle surge help
  • 93royalblue
  • Sep 10, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
Mustang5L5
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
