  • 1994 - 1995 Specific Tech
suspenion ?s
  • Thread starter Thread starter 94GTMOOSE
  • Start date Start date Nov 14, 2006
94GTMOOSE
303
jersey shore
Nov 14, 2006
  • Nov 14, 2006
MY suspension is going to get an overhual. i've been playing on doing shocks and springs, for a while now but just didn't have the cash. my car has 103,697 miles on it, so figure i can't just change the shocks and springs without changing everything else. So here is what i plan on doing and tell me what you think.
03 cobra lower control arms
bumpsteer kit(not sure what brand)
ebiach sport springs
kyb shocks and struts
kenny brown caster plates
and very undecided on what upper and lower control arms for the rear. maybe a panhard bar setup.
i figure i want to do all of this stuff enventually so why take it apart more then once. work smart not hard. plus everything will get even wear. Cash is a issue but i can't skimp on quality so i don't have to replace these parts again for a while.
Stanger007
2,015
Baton Rouge, LA
Nov 14, 2006
  • Nov 14, 2006
How much did you want/have to spend?
I'm trying to figure the same stuff out for my car right now.
95strokerPSU
986
Sacramento from Philly
Nov 14, 2006
  • Nov 14, 2006
That list sounds good.
For bumpsteer I'd recommend Steeda. Probably the most expensive but not too bad at $150.
With the Eibach Sportlines, you might want to consider getting the shocks/struts for a Fox body.
And for UCA/LCA, I think the MM LCAs with stock uppers(new stock replacement bushings) is a very popular combo. I personally went with Steeda Aluminum LCAs and Steeda HD uppers.
Good Luck
HISSIN50
34
129
Nov 14, 2006
  • Nov 14, 2006
KB plates were only C plates IIRC. If so, I'd get CC plates instead (and barring a great deal found somewhere, 4 bolt MM's would be my choice).
Good luck.
95BLKGT5.0
608
Auburn Washington
Nov 14, 2006
  • Nov 14, 2006
Steeda and UPR bumpsteer kits are the same parts, made by the same company the only diff is the name engraved on them and the price. Steeda $150, UPR $99.99
kyb shocks and struts are not very good I would go with Tokico for fox body's.
Like HISSIN50 said KB plates were only C plates IIRC. If so, I'd get CC plates instead (and barring a great deal found somewhere, 4 bolt MM's would be my choice).
94GTMOOSE
303
jersey shore
Nov 14, 2006
  • Nov 14, 2006
here is why i am only going with the kenny brown caster plates. the camber is set all the way so the wheels are set all the way back. thats where the "font end shop" in farimigdale NJ said they were going to set it when i got the car realigned. If its going to be set there to stay, why have it adjustable, only come out of adjustment if i hit a big bump or get air borne.
HISSIN50
34
129
Nov 14, 2006
  • Nov 14, 2006
I think there's some confusion of terms going on here.
94GTMOOSE
303
jersey shore
Nov 14, 2006
  • Nov 14, 2006
maybe. but but it don't matter becasue Kenny brown stoped production of all parts becasue he is in the hospital or somthing like that. they stoped january of last year. So now i must choose a set of cheap but quality CC plates. i am looking to spend like 170 ithink
94GTMOOSE
303
jersey shore
Nov 14, 2006
  • Nov 14, 2006
Mac camber caster plates?
are these good at all. I just know that i need to get a set so that i have enough adjust ment room to make the camber caster what i need it to be. If these do it i am buying them
Methodical
1,192
11
59
Clinton, MD
Nov 14, 2006
#10
  • Nov 14, 2006
  • #10
You may as well get the MM 4 bolt. They can be had for about $189. You are right there. And I think the shop is talking about Caster.
sade04
97
Lansdale, PA
Nov 14, 2006
#11
  • Nov 14, 2006
  • #11
you can get the mm cc plates from stangsuspension for 169.95 shipped if youre a corral member.
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Nov 14, 2006
#12
  • Nov 14, 2006
  • #12
Definitely worth it!
blksn955.o
3,263
st.louis mo 314
Nov 14, 2006
#13
  • Nov 14, 2006
  • #13
I went with bullit springs and getting bullit shocks/struts this winter for them (have some old tokico 5ways now that are done). I like the way the bullit/mach1 handles and they seem to manage a good 60ft in the mags/interwebs/real life. The 03 cobra front a arms are prob. one of the best deals out there and I hope to do them also in the next year or so. I am going to sell my SSM lift bars and get the UPR upper/lower arms that sell for 199$ together. I dont think I will need a bumpsteer kit for my setup though...
Panhard bar would be nice though...
Sub frames I have are D&D full lenghts and it really got it stiff.
-as far as mac I really have not been to happy with macs stuff. I only have delt with one susp. part of theres in the form of the adj. rear uppers on my buddies 00gt and they didnt even have enough adj. to match the length of the stock upper and just plain did not have the adj. needed to really get the use out of the adj. That exp. was par for what others and I have dealt with mac products.
94GTMOOSE
303
jersey shore
Nov 15, 2006
#14
  • Nov 15, 2006
  • #14
ok i think i will go with the steeda lowers with ford racing HD uppers
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
Which Lakewood Front Struts Would Work the Best?
  • 93gtmustang
  • Nov 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 7, 2025
Ethereal_Zer0
E
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
