I just finished my 5 lug conversion (THANKS to Mike and everyone else for chiming in on my previous thread!!) and here's what I had installed:
PBR loaded calipers
13" rotors
SN95 spindles and hubs from junkyard
MM braided front lines
Russell rear braided line
2003 Bullitt wheels
Firehawk Wide Oval Indy 500s in 245/45R17
MM extreme duty rear lower control arms
New axle bushings
FRPP upper rear control arms
FRPP 5 lug rear axle kit with drums
The alignment was done to Maximum Motorsport's recommended specs.
I was giddy to see the car done. I didn't do the work (no time) so I had a client clank everything together. As soon as the car started rolling there was a noticeable loud rumble from what sounded like the bell housing area or maybe in the engine bay (no it wasn't the motor
). The noise definitely increased with speed. My first thought was that the bearings in the hubs were bad but there was no squealing from the wheels and with the windows down I couldn't hear any noise echoing as I drove past buildings. Second thought was that maybe the brake rotors and pads were in contact but the car stops fine with no brake smell when I come to a stop. Third idea was road noise transmitted into the car from the MM extreme duty rear lower control arms. Characteristic of the solid bushings, maybe? The tech at MM said these shouldn't be too much noisier than stock though, and the sound seems to be coming from the front...
Any ideas? The noise in the cabin is going to drive me nuts. It wasn't there before the tweaks but it's certainly something I have to deal with now. It's loud enough to take the fun out of driving it.
Thanks in advance!
PBR loaded calipers
13" rotors
2003 Bullitt wheels
New axle bushings
). The noise definitely increased with speed. My first thought was that the bearings in the hubs were bad but there was no squealing from the wheels and with the windows down I couldn't hear any noise echoing as I drove past buildings. Second thought was that maybe the brake rotors and pads were in contact but the car stops fine with no brake smell when I come to a stop. Third idea was road noise transmitted into the car from the MM extreme duty rear lower control arms. Characteristic of the solid bushings, maybe? The tech at MM said these shouldn't be too much noisier than stock though, and the sound seems to be coming from the front...Any ideas? The noise in the cabin is going to drive me nuts. It wasn't there before the tweaks but it's certainly something I have to deal with now. It's loud enough to take the fun out of driving it.
Thanks in advance!
