Suspension for 65 convertible
  • Thread starter Thread starter AustinBD
  • Start date Start date Oct 4, 2018
A
AustinBD
11
Boise, ID
Oct 4, 2018
  • Oct 4, 2018
Hey all, thanks for the help with the data plate. Moving forward, I was curious about suggestions for a suspension for a 65 convertible. I have the original engine but added the edelbrock power package. Im curious as to what a good suspension for that would be? Im not going to be racing or anything, more of a cruiser with more power. Also, im thinking of putting 17 or 18 inch wheels on it. Would like it to have a good stance without rolling the fenders. Thank you in advance for the help!
rbohm
6,698
550
204
tucson,az
Oct 4, 2018
  • Oct 4, 2018
for a cruiser, the stock suspension properly rebuilt will do just fine. you can do some easy upgrades, like roller spring perches, a one inch lower front spring, i would use the GT rate of 460lb/in for a good ride, upgrade the lower control arm inner pivot point with a spherical bearing to eliminate binding, add adjustable strut rods, lower the upper control arm pivot point on inch, and back 1/8" like shelby did. i would run a 7" wide 17" if you really want a 17" wheel. personally i like the look of a nice 15" better. add in a one inch sway bar and you are done with the front.
in the rear a good 4 1/2" mid eye leaf spring does nicely. add in a set of good shocks and go cruising.
Reactions: AustinBD
A
AustinBD
11
Boise, ID
Oct 4, 2018
  • Oct 4, 2018
This is great, thank you very much. Exactly what I was looking for. Ill take the 15" wheel into consideration!
rbohm
6,698
550
204
tucson,az
Oct 4, 2018
  • Oct 4, 2018
remember that with the larger wheels, you need more backspacing to clear everything. i plan on going with a 15x7 wheel on all four corners, and running either a 205/65-15 or a 215/60-15 tire all around. for a driver or a cruiser, its a nice package, and you really dont need a lot of tire with these cars because of their light weight.
Reactions: AustinBD
A
AustinBD
11
Boise, ID
Oct 4, 2018
  • Oct 4, 2018
Is there one that you would recommend that would give it a nice stance? I have seen so many posts about it but mostly with rolled fenders. I want a nice stance, probably on 17x7, no rolled fenders. Would I also need spacers to give it a much better look? Thank you again!
rbohm
6,698
550
204
tucson,az
Oct 5, 2018
  • Oct 5, 2018
the backspacing is the key here. as i recall a 17x8 wheel needs 5.75" backspace to fit properly, a 17x7 fits better, but still needs 5.25" backspace. dodgestang has a chart on the backspacing that fit mustangs best. it should be somewhere here on the site.
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
65 Coupe I6 Auto to 302 EFI 5 Speed Swap
  • Scuderia
  • Feb 3, 2025
2K
1965 - 1973 Classic Mustangs -General/Talk- Sep 9, 2025
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Interior and Upholstery Waterproofing interior
  • MementoMori
  • Jun 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 14, 2025
MementoMori
