  • SN95 4.6L Mustang Tech
Suspension Guru's please answer question
  • Thread starter Thread starter Mr Plow
  • Start date Start date Feb 15, 2004
Mr Plow
148
Suffolk, Long Island
Feb 15, 2004
  • Feb 15, 2004
A little over a week ago I had Tockico shocks, struts and springs installed. I took at measurement today of each wheel location and here are the results:
Measurement taken from bottom of rim lip to fenderwell:
Driver side front: 24"
Driver side rear: 24 1/2"
Passenger front: 24 1/2"
Pasenger rear: 25 1/2"
I am definately going to assume something is wrong here. Please give me some insight to this problem, and if this is not the way its suppose to be let me know so I can go back to the shop to get it corrected. Thanks in advance for any help!!
Dan
M
MaxMustang
53
  • Feb 15, 2004
If you didn't do any measurements before you did the upgrades you will never know. Mustang body panels are never even from side to side.
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Feb 15, 2004
  • Feb 15, 2004
are you sure you got those measurements while the car was on even ground?
luther1228
138
Baton Rouge, LA
Feb 15, 2004
  • Feb 15, 2004
shocks and struts dont determine ride height springs do. you need to see if your springs are all facing the same way
scheister
612
Indy
Feb 15, 2004
  • Feb 15, 2004
one more thing too....don't forget that you will need to wait for the car to settle from the new parts
03Sleeper
464
Fordville,USA
Feb 15, 2004
  • Feb 15, 2004
I agree!
I would make sure they are seatted and then Measure on a level surface and do your measurements to the FRAME and not the Body panels..
Goodluck
Andy
P.s. I have H&R's and I got 25 3/4" all the way around with in 1/8" and I blame that on the Body panels. I thought H&R's where as low as they went so what Springs are you installing??
those mesurements seem OFF Unless mine need to settle more?
Mr Plow
148
Feb 16, 2004
  • Feb 16, 2004
The installed springs were Tokico. I was thinking that a rubber isolator was left in on the passenger rear or something. I appreciate all comments and help. I measured on level ground, and you can see how the car is on an angle, lower on the drivers side, when you look from the rear. I guess I will let it settle some more before I bring it to my shop. Thanks again.
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
Fox Ideas for Theft Deterrence in Storage
  • Clutchfork
  • Nov 6, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 1, 2025
91AOD5.0LX
