5.02GO said:
So basically spring isolators, oem shocks/struts and end links. Possibly a
panhard maybe even a stiffer sway bar.
Panhard which brand to get?
Any ideas about getting ford shocks/struts without going to a ford dealer?
You're welcome. I wish I had read your first post slower initially. Anyway, the OEM parts were Macpherson, and I suppose you could hunt them down outside a Ford dealer. Dealers do like to bend you over the parts counter. Most other parts stores are going to sell you Monroe Sensatrack stuff as a stock replacement, and they are a sound product. Not what I would consider an upgrade, but I'm not sure that's what you want.
The
panhard I suggested on the off chance that you wanted to improve your handling performance beyond how it was when new- as I said, the clumsy four link rear is the biggest problem with these cars. It is simply a BAD design. Everyone goes and puts on lowering springs and adjustable shocks and think they really have something when they only bandaided the problem. It feels way better, but the limits of the car haven't improved, it's no more predictable, controllable or forgiving when the limits approached, and there isn't a whole lot of warning- because the rear is steering the car, not you and it is in control. It isn't true, but I'll go to my grave saying that the phrase "snap oversteer" was made just for the Fox Mustang. Stiffer shocks and springs just distract you from the real problem which isn't fixed, and for most drivers that's good enough. I'm not under the impression you want to compromise your ride quality for the illusion of more control. However, if you aren't a very aggressive driver, than you may not need a
panhard either. The single biggest improvement you can make in your performance handling is tires, and you've done it.
Regardless, which company to go (if you decide to) with depends on what's important to you. You need to talk to the major
suspension companies and find out from the horses mouth what the pluses are to their design, and what compromises you'll have to make. Some attach more structurally sound to the frame, some don't allow you to run tail pipes, some have aluminum rods instead of steel (so they won't tweak your frame in a side collision) etc. Same with watts links, although they are (arguably superior to the
panhard on the track, but) not always as easy to live with on the street. Then just go with whoever you're comfortable with. I stand behind the Maximum Motorsports design, but I really don't think you can go wrong with any of the makers who race what they sell... any one of them will be better than what Ford was too cheap to put in themselves.
