suspension help
  • Thread starter Thread starter Haus
  • Start date Start date Dec 13, 2008
H
Haus
408
  • Dec 13, 2008
ok i got a 92 5.0 on the car its got like 170,000 miles and i believe the shocks, struts and springs are original. ok heres what i want. this is not a race car or am i gonna to be racing at all. i want something that rides nice. right now i feel every little bump in the road making a huge thud.
ok so i want something that will be comftable going over bumps. alot of crappy roads where i live. but i want it to have a nice aggresive stance as well. so i want to lower it a bit. so my questions are...
What kind of shocks and struts can i get that will give the the ride quality and what lowering springs can i get that will work with the ride quality i want.(i dont want it to be completely slammed) and not want to spend to much money.
dcurtis
688
Dec 13, 2008
  • Dec 13, 2008
I say go with the eibach pro springs or the ford racing b-springs, they are not a drastic drop but they do drop your vehicle decently, but not as drasticly as the sportlines or the c-springs, and I think h&r springs are just too stiff, have no experiance with bbk or any others, the springs I recommended drop around 1 to 1.5'', which sounds like what you are looking for, and they are a progressive spring which will give a better ride quality than a specific rate spring would. As far as the shocks and struts go I don't have any recommendations other that try and match them to the spring pressures of what ever you get, I have monroe shocks and struts installed in my car and they were just stock replacements.
LiquidGT
368
Near STL hell
Dec 13, 2008
  • Dec 13, 2008
I just picked up some Bullitt springs, from what I read the Bullitts' will make a Fox ride and handle much better; they're supposed to drop a Fox 3/4 at the most. Some paired them up with Tokico HP (blue) shocks, while others use Bulllitt shocks, either way they say it rides better than a stock fox, especially one with a worn suspension; I'm hoping to get some Tokico blues for mine.
MahFiVeOh
531
9
49
Ontario, Canada
Dec 13, 2008
  • Dec 13, 2008
I just replaced my "unknown" lowering springs with Steeda Sports along with Monroe (stock replacement) shocks and struts on mine.The shocks and struts were both original so you could probably imagine how it rode before the new parts.The springs lower it approx 1 1/4 inches.The ride is pretty nice, its not bone jarring when you hit bumps in the road (roads are bad here)
Beasty306GT
671
Oxford,Mass
Dec 13, 2008
  • Dec 13, 2008
Get yourself some strange 10 way adjustable shocks and struts...u can control ur ride with a turn of a knob....use some ford racing springs...they drop the car no more that an inch
cenok is family
1,409
69
79
Norman, Ok
Dec 13, 2008
  • Dec 13, 2008
a good budget setup would be tokico HP's (blues), and ford racing B springs or bullitt springs like liquidgt said. Over those though, if you can afford it go with the eibach pro kit springs
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Dec 13, 2008
  • Dec 13, 2008
Eibach pro lowering kit
Shocks-koni, qa1 adjustable or equivalent, there is alot of good shocks out there. I just happen to know these work from experience.
Ones i do not like are bilstein.
And most importantly, use energysuspension isolator kits all the way around, world of difference. Takes all the thumps out of bumps.
H
Haus
408
  • Dec 14, 2008
ok so i have decided to go with this if it will go together
Tokico Blue shocks and struts and Ford Racing B-Springs.
and thanks for all your replys
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
