Ok lets see if you guys can help since no one on my falcon boards helped... I have a 64 Falcon which has the same suspension as a 65-66 mustang.. Heres my issue. I just put all new suspension on the front of my falcon, everything is new. I did the granada swap also. Now it looks wonderful everything fit perfect, but my problem is when I jack the car up everything drops to its lowest point, well that takes the spring out of its top perch, so when I lower it I have to run around to each side and inch the spring back in its perch. Everything is tight and I cant figure out what else to do. The springs I used are the 620 rate with a half coil cut off, but even if I hadnt cut a half coil its still dropping to far like 2-3 inchs.... Any help would be appreciated.
- Kurt
- Kurt
