Suspension package?
  • Thread starter Thread starter theautomatics
  • Start date Start date Mar 19, 2008
T
theautomatics
37
Chicago
Mar 19, 2008
  • Mar 19, 2008
I'm looking for a suspension upgrade package for my 67 mustang. I'd like spring perch and idler arm, sway bar and maybe upper control arms.
Can you recommend a good package? This would be for a mid 12 second street car.
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Mar 19, 2008
  • Mar 19, 2008
What kind of driving do you want to do with it? A quarter mile setup is far different from a corner carving setup. Also - how much do you want to spend?
SadbutTrue
2,391
Thousand Oaks, California
Mar 19, 2008
  • Mar 19, 2008
NPD has pretty much any type of suspension package you might want... ranging from basic sway bar (f,r)/spring (f,r)/bushing/shock combinations to $10,000 coil over things and everything in between.
Opentracker has most of that stuff too.
You have lots of options, might want to narrow down your price range, goals, whats already been done to the car, etc.
T
theautomatics
37
Chicago
Mar 19, 2008
  • Mar 19, 2008
How much can I spend - whatever it takes to have the power go to the wheels somewhat efficiently.
What's done to the car....... In terms of suspension it's stock. Otherwise new motor, trans, rear end (posi) and drive shaft. My goal is city driving suspension because it'll spend most of its time from light to light.
i'll check those companies for packages. This will be my first suspension upgrade.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Mar 20, 2008
  • Mar 20, 2008
If you are going to stay with a stock style suspension definately get the Opentracker roller spring perches.
Put poly on all the dustboots and stay away from poly for the lower arm bushing as it will make your ride a lot more harsh.
Opentracker also has a roller idler arm which should help to smooth out the steering a bit. If you end up needed the steering box rebuilt check out http://www.stangerssite.com/ He has quite a good reputation.
I would suguest calling up John over at Opentracker and having a talk with him. He will get you straight and only sell you what you need, nothing more.
T
theautomatics
37
Chicago
Mar 20, 2008
  • Mar 20, 2008
Golden! Thanks a ton. How did you know my 67 was really hard to steer...... hmmm
M
Bent Rear Spring Perches
  • Miozu
  • Aug 18, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 8, 2025
PSKSAM2
P
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
