  • 2.3L (N/A & Turbo) Tech
suspension question
  • Thread starter Thread starter blacksheep-1
  • Start date Start date Oct 26, 2007
blacksheep-1
322
Oct 26, 2007
  • Oct 26, 2007
When I lowerred my 99 I (eventually) added 2 more mods, one was the bumpsteer kit, and the other was the extended front ball joint (both from Steeda) the reason for this is that when lowerred, the roll center of the car ends up below pavement level. Believe me, those 2 mods were WELL worth the money as far as handling. So here's the question, no one that I know of lists the extended ball joint for the 79-93 cars. Is it because the suspension is different and they're not needed, or is it just because there is no market for them?
Also, would anybody out there know how much to saw off of a 93, 2.3 double plug head to get 11.5 to 1 compression?
Thanks.
tomustang
Psychotic Member
3,434
McLean Hospital
Oct 26, 2007
  • Oct 26, 2007
Thanks.
Webpage info:
From Steeda Website said:
APPLICATION INFORMATION
PN: 555-8101 fits 94-03 Mustangs. It also fits 87-93 Mustangs that are equipped with the Ford Racing M-2300-K Cobra Brake conversion kit or Baer 13" or 12 " American Sedan Brake kits. It will not work with stock 87-93 brakes because of interference between the rotor and the repositioned control arm.
http://www.steeda.com/products/x2_balljoints.php
I would figure that if you upgraded to a 94+ brakes/spindles it might work, but I'm not sure
About the 2.3 question, I don't know, you can search the 2.3L section but it's kinda dead in here all the time.
If you do get it shaved don't forget to readjust the timing
blacksheep-1
322
Oct 27, 2007
  • Oct 27, 2007
I wonder if some "grinder work" would let it clear, or is it too big of a problem?
E
ethangsmith
227
Manheim, PA
Oct 27, 2007
  • Oct 27, 2007
From what I have been told, if you mill the 2.3L head down to where it is just below the lowest intake bolt holes, that is about 12:1 compression.
Red_LX
I’m not much help unless you’re looking for ****!
73
129
Morgantown, WV...where couches meet their doom
Oct 28, 2007
  • Oct 28, 2007
I coulda swore I saw a "long" balljoint kit somewhere for '87-93 cars but maybe I'm wrong.
P
Suspension Different height ball joints?
  • pindude80
  • Jun 10, 2024
3K
Fox 5.0 Mustang Tech Jun 12, 2024
limp
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
SN95 Sway Bar Endlink Issues!
  • Swizzy
  • May 10, 2024
1996 - 2004 SN95 Mustang -General/Talk- May 13, 2024
Swizzy
