suspension sounds
maxima
146
its an 06 gt , is anyones suspention noisy , make clunky sounds over bumps or pulling in to a driveway clunky and raddles , drving on the highway its fine .thanks
This may be a TSB issue. I have an 07, and while it is not the quietest car, it is nothing I would really notice as out of the ordinary. I think there was a TSB where some cars have the transmission mount put on upside down, and that needs to be corrected.
Here is the TSB list, you can spend an afternoon going through all the possible problems.
S197 Ford Mustang Technical Service Bulletins - Ford Mustang | StangNet.com
Mine started doing that after I put the H@R race springs and Koni's on it. My suspension noise is not very loud though. I find the factory engineered driveshaft clunks more annoying.
when going over bumps? also when i hit decent bumps the top of my dashboard bangs down , it just makes the car feel like a 1966 stang instead of an 06
The dash board banging is not normal. My suspension clunks sometimes going into off camber parking lots. But my suspension is very stiff, I consider it normal. When the car had the stock suspension, it was dead silent. Some of the noise you hear might be the driveshaft, they are known to make clunking sounds at slow speeds or shifting. I would be more concerned with the dash issue.
