  • SN95 4.6L Mustang Tech
Suspension Woes
  • Thread starter Thread starter 1fast03pony
  • Start date Start date Feb 14, 2004
First Prev 2 of 2
bird
342
Garden City, NY
Mar 4, 2004
#21
  • Mar 4, 2004
  • #21
1fast03pony said:
i apologize.. im at school, the pics are on my home pc. completely forgot. ill post them when i get home for sure. you have my word
How low of a Drop did you do?
Rob
1fast03pony
749
New york
Mar 4, 2004
#22
  • Mar 4, 2004
  • #22
Rob
theres a two fingerwidth gap between the wheels and the fender in the front
and a little more in the back
Id say it dropped a good 1.75 in. in the front like advertised and 1.5 or so in the back. I was pleased with it. ill def post pics sorry i forgot.
bird
342
Garden City, NY
Mar 4, 2004
#23
  • Mar 4, 2004
  • #23
Did you install a Ford Aluminium Drive shaft? Also do you know the spring rates of the springs you bought?
Rob
TheRedBlur
15
seattle
Mar 5, 2004
#24
  • Mar 5, 2004
  • #24
does it happen when you are stopping? and then happens again when you start going from a dead stop?
1fast03pony
749
New york
Mar 5, 2004
#25
  • Mar 5, 2004
  • #25
no it just happens when hitting bumps
also the spring rates are 700-760 lb./in. in the front, approx 300 lb./in. in the back.
edit: no i didnt install the aluminum driveshaft... yet.
bird
342
Garden City, NY
Mar 5, 2004
#26
  • Mar 5, 2004
  • #26
Just for kicks. If you can or the next time you are under the car. Look to see if your drive shaft has any groves. Sometimes when you lower the car along with soft springs in the rear the drive shaft can rub up against the parking brake cable guides.
I also have a guy I use on Long Island the specializes in mustang suspension and he solved some major issues (wired noises and Rubbing) I was having with mine. If you want his # please let me know. It would not suprize me if he would solve your problems
Rob
1fast03pony
749
New york
Mar 5, 2004
#27
  • Mar 5, 2004
  • #27
Rob
Rob if you could PM me with his number that would be great. thanks, ill check the driveshaft today.
-Jon
bird
342
Garden City, NY
Mar 5, 2004
#28
  • Mar 5, 2004
  • #28
-Jon
PM sent
01LaserRedCobra
318
#29
  • Mar 8, 2004
  • #29
1fastpony
I was just curious if you happened to find out what that noise is we both have? I have been in Vegas and just got back? If you found out anything new let me know? I was going to do some work tomorrow on the car to see if I can find the problem.
Thanks
1fast03pony
749
New york
Mar 8, 2004
#30
  • Mar 8, 2004
  • #30
01LaserRedCobra said:
1fastpony
Thanks
Im making an appointment to have a suspension expert check the car out saturday. Ill let you know what happens. if you find something def. let me know.
01LaserRedCobra
318
#31
  • Mar 10, 2004
  • #31
Well last night I jacked up the car again... and made sure everything was torqued down to specs in the front end.. Kmember, control arms, sway bar link/bracket, strut bolts to spindle. I also took the time to thouroughly search around the front end to see if there has been contact anywhere, but nothing. I still get the freaking noise from the front.... I really wish I could figure this one out??? Please help if anyone else has any ideas. It seems other people have this exact same issue?
Thanks,
DB96GT
385
AZ
Mar 10, 2004
#32
  • Mar 10, 2004
  • #32
Can't you put the car on stands, allow the front wheels to hang in the air, kick the wheels and replicate the noise?
I had a clunk in the front like that once. It turned out that I didn't tighten the caliper mounting bolts tight enough and the caliper was rattling around a little, on bump. The 15mm bolts. It took me weeks to find that.
01LaserRedCobra
318
#33
  • Mar 10, 2004
  • #33
Ya I checked that they are torqued to 100ft. lbs
01LaserRedCobra
318
#34
  • Mar 11, 2004
  • #34
1fastpony and others try to tighten down your transmission cross member. Another person said that it helps. I tightened my down tonight and tested it a little. It seems to help a little, but going over things like train tracks you definately still hear it.
You may want to torque down the bolts a bit more than what is recomended... (see attatched .doc)
First Prev 2 of 2
  • dan50
  • Jul 18, 2026
dan50
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
H
New kid on the block
  • HydraX
  • Mar 22, 2025
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2025
HydraX
H
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
