  • SN95 4.6L Mustang Tech
SVE Mongoose Clutch
  • Thread starter Thread starter apats77
  • Start date Start date Sep 15, 2011
apats77
178
Watertown, MA
Sep 15, 2011
  • Sep 15, 2011
Installed the mongoose and a new Ford Racing Nodular flywheel, from stop the clutch slips quite a bit and almost every time in reverse. It slips enough that I can smell it. After about 10 minutes of stop and go the clutch grabs fine.
Is this just part of the wearing in period?
LRSjmac
Premium Sponsor
Sep 9, 2008
335
Hewitt, Tx
Sep 16, 2011
  • Sep 16, 2011
Definitely not. Cable adjustment appears to be incorrect. What cable/quadrant setup are you using? In relation to pedal travel, where does the clutch start to disengage/engage?
apats77
178
Watertown, MA
Sep 16, 2011
  • Sep 16, 2011
its stock cable and quad. it is adjusted to its max already, cable is stretched out?
it starts to grab at about half way.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Sep 16, 2011
  • Sep 16, 2011
stock cable and quad are junk , put a good one on it and adjust it
LRSjmac
Premium Sponsor
Sep 9, 2008
335
Hewitt, Tx
Sep 19, 2011
  • Sep 19, 2011
Agreed, stock quad at least needs to go. You can run a triple hook aluminum quad with a firewall adjuster on your stock cable if it still is in serviceable condition.
Also, noticed your sig says 2.73 gears. With that high of a ratio, you are having to slip your clutch a bit on takeoff, so that does play a small role.
apats77
178
Watertown, MA
Sep 22, 2011
  • Sep 22, 2011
Just ordered a steeda cable and quad from LRS, also in the process of installing 3.73's.
Thank you for the responds. LRS has been a huge help in my recent build, Spent about $500 so far. I think its awesome that you monitor the forums.
LRSjmac
Premium Sponsor
Sep 9, 2008
335
Hewitt, Tx
Sep 22, 2011
  • Sep 22, 2011
No problem, it's what we're here for!
Definitely appreciate the business, & if you ever have any questions don't hesitate to give us a call or PM me here on the forum.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
