svo brake hose vs mark vii brake hose
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
im running mark vii calipers, with foxbody brake lines, i have my old brake hoses(had lincoln rear disk to disk brake lines and all) but they look like they need a 1/4" hard line and not the 3/16th hard line like the foxbody uses. the 86 SVO i believe uses a 3/16th brake line though with the same caliper. do you know if the SVO hose's will work with the foxbody 3/16th line
after a few calls to a few auto part stores i went with SVO lines. they have the correct 3/8-24 fitting for a 3/16 brake line. the lincoln uses a 1/4" line and if im having to cut and reflare stainless steel brake line im not going to both dicking with extra fittings
