Swap from automatic to manual, how hard is it?
mtmc
38
VA
Just out of curiosity, how hard is it to swap from an automatic to a manual in a '96 mustang gt? My car is automatic now and I found a manual tranny with clutch assembly, and flywheel, out of a '96 cobra. I know a guy with a pedal assembly and a clutch cable. I can find a shifter and the interior pieces but what else is needed? Will I need a "manual" ecm? Also, what would I do with the factory wiring harness that went to the 4R70W?
Search for posts by me. I listed most things out recently. Off the top of my head you also need...
Either get a manual ECU or have a tuner adjust yours.
Manual trans wiring harness (mine is part 15525 I think)
Engine block plate (50resto)
Clutch quadrant, cable, firewall adjuster
Yoke from manual driveshaft or aluminum DS
Ford Clutch fork kit
Lower shift boot
Trans fluid
