  • SN95 V6 Mustang Tech
swaping to an 8.8
  • Thread starter Thread starter 5.O STANG
  • Start date Start date May 9, 2006
5.O STANG
44
  • May 9, 2006
My friend with an 00 V6 wants my stock 03 gt axles, posi and gears. What else would he need if anything to make them fit in his 00 v6.
9
97sally6
129
  • May 9, 2006
nothing really, its supposed to be a direct bolt in swap
edit: now that i think about it, he'll probably need your whole rear end to make it work, or scrounge one up from a junkyard, because 8.8 gears and diff wont fit in an 7.5 housing, same with the axles, and he'll need to recalibrate his speedometer for the new gear.. sorry for the confusion
Silentst2000
145
  • May 11, 2006
the 8.8 housing itsself and if he wants some quad shocks.
V
v6charged00
  • May 13, 2006
for a good swap all you really need is the 8.8 housing, the gears, diff, you can use the axles from your 7.5...you only need to recalibrate your speedo if your changing gear ratio...i think stock they are 3.15
9
97sally6
129
  • May 13, 2006
aren't the stock gt gears different than the stock V6 gears?
Lsredy2kstang
Look, I'm special, dammit
Woodstcock, Georgia
May 14, 2006
  • May 14, 2006
Depends on the year. Some came with 2.73's in the rear and some with 3.27. Most are 3.27 just for the 7.5 versus the 8.8.
tomustang
Psychotic Member
3,434
McLean Hospital
May 14, 2006
  • May 14, 2006
99-04: 3.27's
94-98: 2.73, 3.08, (cobra's 3.27)
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
D
97 V6 suspension upgrades
  • Dale1bre
  • Jan 18, 2026
SN95 V6 Mustang Tech Jan 19, 2026
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
F
Please help 00 mustang 3.8 v6 T5 manual transmission Tail housing cracking
  • FF-DC00
  • Jan 2, 2025
SN95 V6 Mustang Tech Jan 2, 2025
General karthief
