swapping fox wiring into 94-95GT ???
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
I can trash just about everything under the hood right ?
Anybody done this ?
Can the IAC and TPS wires just be spliced and soldered to the 94-95 pigtails ?
What wires do I need to keep in the car at the PCM to get power to it ? and what wires , relays , etc. can I get rid of ?
Car has an aeromotive fuel system with its own power and relay so I should be able to just find the Fuel pump output wire from the PCM and wire it to the relay for the aeromotive pump directly right ?
I have trashed many things under the hood, but not everything. The fox tps can be spliced into the 94- 95 harness, the IAC is the same connector for both models.
Hiding the wires may be a better choice than getting rid of something you may need in the future. Believe me I have been there.
I also found the fuel pump wire at the back of the car in the trunk area for the aeromotive pump. One difficulty was the short prime time of the stock pump didn't allow me to get fuel pressure until I turned the key a few times. If your using stock fuel lines you should be fine, if you upgraded, you may want to look at alternative method of fuel pump power.
