swapping header gaskets, any tips
  • Thread starter Thread starter legalize420
  • Start date Start date Jul 18, 2005
legalize420
1,541
South Florida
Jul 18, 2005
  • Jul 18, 2005
i did a search and was reading some of the old threads and i came to the conclusion that i am going swap out the copper gaskets that came with the mac headers and going with the felpro. i have that ticking noise and im hoping this will solve it. i wanted to ask if anyone knows any good tips to make this go smooth as possible. also, what tools or wrenches does everyone find to work the best. my bolts backed out a little while back and one even fell out. i originally had some buddies of mine do the exhaust and i guess i never made sure to check them after a few heat cycles. i know that when i replaced the one that fell out and when i tighted the loose ones it was a huge PITA with a 7/16 ( i think thats what it was) wrench. any suggestions, thanks.
M
mackey
1,284
Beverly, Massachusetts
Jul 18, 2005
  • Jul 18, 2005
Get the header bolts which have hex heads that can also be tightened by allen wrenches. If you don't want to pay the money for the stage 8 locking bolts throw some lockwashers under them.
281pony
2,681
Oly, WA
Jul 18, 2005
  • Jul 18, 2005
loosen the bolts at the collector, remove all header bolts. should be enough room to move it over so you can slip the old gasket out, and a new gasket inplace.
start the first and the last bolt to get the gasket in place first. thats how ive always done it.
ratcheting wrench and 3/8" header bolts> allen head bolts in my experience
46defense
445
Sanford Fl.
Jul 18, 2005
  • Jul 18, 2005
Get the stage 8 locking bolts. They are worth every penny. I had this problem with my BBK's and I'm pretty sure you've got the same deal. Once the bolts back out, the gasket burns up and falls out, and you get that ticking exhaust leak sound. I never had this problem with my first set of Mac's, I was assuming because of the seperate header flanges for each pipe let the bolt stay tight. Which was exactly the same reason I didn't want the Mac's the second time around. By the time you ding them to fit around the steering shaft those damn pipes were sprung out all over the map, making it nearly impossible to bolt them on. Anyway, on the BBK's I used the Stage 8's and they can't back out. They are the be all, end all.
legalize420
1,541
South Florida
Jul 18, 2005
  • Jul 18, 2005
do most of the hex head ones have the allen key heads or is there a certain one i need.
legalize420
1,541
South Florida
Jul 18, 2005
  • Jul 18, 2005
does anyone know if the copper gaskets that come with the mac headers slide out or will i have to take the bolts out. i did not install them so i have no clue.
SamSnyder
196
  • Jul 18, 2005
I just got them as loose grade 8 allen head bolts of the same size and length as regular header bolts. Any well-equipped hardware store should be able to come up with them. I also used locktite red on them. Also, I got a ball-end allen wrench, which really helped, because you can get the wrench in at off-angles.
There's another issue here however. My Mac shorties had individual flanges at each port, and when I pulled them at engine swap time, they would not line back up -- the cycling heat caused the tubes to bend, and unbolting them set them free. I ultimately got them back on by standing on the collector and using a barbell pipe in each flange/tube to bend them back into approximate shape, using my stock shorties as a guide.
The point is that you will probably face this tweaked tube syndrome as well, and I am wondering if it would not be possible to get the old gaskets out without fully removing all the bolts. Does anybody know? Could the bolts be backed out a bit, the old gasket cut out and the new one installed by keyholing each bolt hole in the new gasket, for a drop-in install? Not fully removing those bolts would probably save a big pain in the a$$ if it could be done. Anybody ever try this?
legalize420
1,541
South Florida
Jul 18, 2005
  • Jul 18, 2005
i hope that is not the case. i guess i will need to find out if the gaskets can slide out just to be safe and get some that will drop in. does anyone know if the felpro 1415 drops in?
legalize420
1,541
South Florida
Jul 18, 2005
  • Jul 18, 2005
what is the difference between hex, external hex, and double hex. which ones have the allen key.
SamSnyder
196
#10
  • Jul 18, 2005
  • #10
An allen head bolt (aka socket head) is usually round, so you can't uses a regular wrench on it. Instead, it has a socket that will accept an allen wrench, also known as a hex key. A regular bolt has a hex-shaped head on it and works with a regular wrench. And yes, I am afraid that the curse of the tweaked individually flanged Mac header tubes awaits.
legalize420
1,541
South Florida
Jul 18, 2005
#11
  • Jul 18, 2005
  • #11
do you know where i can get the bolts you are talking about?
legalize420
1,541
South Florida
Jul 18, 2005
#12
  • Jul 18, 2005
  • #12
i have a whole set of bolts that i ordered when i lost one bolt a few months ago so i wanted to put them to use. if i get the locking washers will the 3/4 bolt be long enough or will i need the 1 inch?
SamSnyder
196
#13
  • Jul 18, 2005
  • #13
You should be able to get them at any well-equipped hardware store. Grade 8 allen head bolts. I'm not sure about the size -- was it 1/2 x 1.5" or 7/16 x 1.5"? Something like that.
legalize420
1,541
South Florida
Jul 18, 2005
#14
  • Jul 18, 2005
  • #14
is that the size for the lock washers. i was actually asking about the bolts. the header bolts are 3/8 16 right. but which length with the washers,3/4 or 1 inch. i will check into finding a good hardware stoe around here
Ranchero5.0
The Voice of Reason
Jan 1, 1999
5,306
Hagerstown MD
Jul 18, 2005
#15
  • Jul 18, 2005
  • #15
First step in this is probally ordering a set of BBK shorties with the one piece flange, toss the gaskets and 3/4" bolts. Buy a set of 3/8-16 x 1" header bolts and some permatex ultra rtv. Put a 1/8" bead areound each port and lock it down. The gasket swelling causes the bolts to loosen so no gasket no loosening of the bolts. The BBk 3/8" flange needs a longer bolt to get plenty of threads holding it together.
This is what I do on customers cars and I will never ever install another set ot MAC headers. You can eBay them for around $60-80 and be better off in the long run.
Jamie
legalize420
1,541
South Florida
Jul 18, 2005
#16
  • Jul 18, 2005
  • #16
if i consider getting long tubes will they hook right up to the pro chamber? what about fox long tubes? i have my egr capped off. is that the only difference?
legalize420
1,541
South Florida
Jul 18, 2005
#17
  • Jul 18, 2005
  • #17
looks like i can take the gaskets out without taking them completly off. do you think i will still have a posible problem with the flanges regardless?
http://cgi.ebay.com/ebaymotors/NEW-...987867335QQcategoryZ33666QQrdZ1QQcmdZViewItem
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
