  • 1994 - 1995 Specific Tech
Swapping sn95 engine with fox engine
  • Thread starter Thread starter syburstang
  • Start date Start date Aug 22, 2005
syburstang
17
San Diego, CA from SA, TX
Aug 22, 2005
  • Aug 22, 2005
From what I've gathered some of the pulley's go different directions, the lower intake is different, the distributor is different, the power steering pump is different, and the TB setup is different....however if I just did an entire engine swap with the exception of the TB setup would I have any problems? Like will it matter if the pulley's go the opposite direction? I'm going to keep the fox A9L comp in the fox and the sn95 comp in the sn95, and I'm going to swap the power steering pumps(if in fact they spin in a different direction). Would it mess with the A9L that the distributor is different and the pulley rotation is different? So in the end I plan on having an entire sn95 engine bay with the exception of the injector wiring harness in a fox...and vice versus....will it work? Thanks in advance for the help.
WHITE94COBRA
816
HUNTINGTON BEACH
Aug 22, 2005
  • Aug 22, 2005
WHY????????
Same engine couple different parts????
HISSIN50
34
129
Aug 22, 2005
  • Aug 22, 2005
I think he wants his go-fast 331 in the fox.
94TURBO5 O
2,509
VA
Aug 22, 2005
  • Aug 22, 2005
I have an 87 GT long block waiting to go in and all I did so far is change the timing cover to accept the SN water pump and changed over the crank pulley.
syburstang
17
Aug 22, 2005
  • Aug 22, 2005
The reason for my swap is I want the 95 California legal, and the 331 would be nice in the fox!
WHITE94COBRA
816
HUNTINGTON BEACH
Aug 22, 2005
  • Aug 22, 2005
Ok Now It Makes Cense!!
G
GTwannaB
44
the middle of nowhere
Aug 22, 2005
  • Aug 22, 2005
your gonna find that the accesories being in different spots wont fit in the sn95 engine compartment your going to need to put all newer brackts on
syburstang
17
Aug 23, 2005
  • Aug 23, 2005
Thanks guys. I decided to just leave the 331 in and register it in TX. CA sucks when it comes to that emissions garbage. I also decided not to buy the stocker fox because I already have my 89. That saved me from having to battle it out with the wife on why I needed a fourth car..hehe.
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
K
Fox body swapped sn95
  • Konstang
  • Apr 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2025
95BlueStallion
