  • 1994 - 1995 Specific Tech
sway bar broke
  • Thread starter Thread starter 95mustang_gt
  • Start date Start date Aug 26, 2005
9
95mustang_gt
364
Wisconsin
Aug 26, 2005
  • Aug 26, 2005
Just making sure, is the sway bar the curvy bar,in the front and back.
If it is my just broke , I was just droving along and I start hearing this metal hitting metal sound. So I pull over thinking it was something in the trunk, took everything out and still heard the sound. So I look under the car in the passenger side and look towards the back and see this piece of metal coming down, it broke off, its not bad,its just when I drive and hit hits the ground and the metal.
So my question is, should I buy a stock one or an aftermarket? How much do they run and can I take it off and drive with out it? Is it easy to take off and install?
Thanks for any help
CManT1914
3,172
Killeen, Texas
Aug 26, 2005
  • Aug 26, 2005
Yep, that's the sway bar. I broke mine too. It's a common problem on our stangs. Don't even bother buying a factory one. Get an Eibach or the likes and never look back. They are super easy to install. Just 4 bolts really. The front is a little harder than the rear if you do both, but it's definitely worth it. You can drive without it on if you need to. I did for about 2 weeks, and there wasn't any major bad effects.
9
95mustang_gt
364
Wisconsin
Aug 26, 2005
  • Aug 26, 2005
thanks for the help bro
WhiteDevil
2,717
San Diego
Aug 26, 2005
  • Aug 26, 2005
Yeah mine broke too, i drove without one for like over a year, the funny thing is i didnt notice any change when i took it off but i noticed it felt better when i put a new one on.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Aug 27, 2005
  • Aug 27, 2005
Yup, traction will be killed w/o it in the rear. The front one can be ditched asap.
If you are cheap or broke, just weld it back together.
Scott
HISSIN50
34
129
Aug 27, 2005
  • Aug 27, 2005
Did the sway bar break, or the end link?
You guys are hard on those anti-sway bars (Scott, I think John just broke his rear bar recently).
Good luck.
Redsnake2
374
Philly, PA
Aug 30, 2005
  • Aug 30, 2005
same here, mine broke also, and i took it off and I have'nt replaced it yet. the Cobra one from Ford is $100, don't know how much the Eibach one is. But i do notice a little differance in handling.. Not much, but enough to know i want to replace it.
?????? If i lose the front sway bar will that effect my handling alot?
Steeda90GT
714
Central Jersey
Aug 30, 2005
  • Aug 30, 2005
I think they're selling the Bullit Front and Rear sway bars for $69.99.
tomustang
Psychotic Member
3,434
McLean Hospital
Aug 30, 2005
  • Aug 30, 2005
common problem, best replacement is a solid cobra upgrade, you can find them for about $100
Scott_95GT
387
Sacramento
Aug 30, 2005
#10
  • Aug 30, 2005
  • #10
I have had two 95 GT's: 2 broken rear sway bars.
W
Westee
36
#11
  • Aug 30, 2005
  • #11
Mine broke and I had it welded back together. Then it broke in another spot. My buddy's broke on his 97 stang too. I just ditched mine....
Zero Signal
2,633
Tucson, AZ
Aug 30, 2005
#12
  • Aug 30, 2005
  • #12
Broke two here. I have no sway bar at the moment, lol.
The problem is that our rear suspension has a lot of lateral play and bind. And since our sway bar has no bushings or anything else confining it's movement to pure torsion, it's subjected to alot of bending as well. I think a panhard bar would fix it. Really stupid design I say.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Aug 30, 2005
#13
  • Aug 30, 2005
  • #13
Yeah, a solid tubular bar is a bad design.
But the less play, the more the rear end will plant, and the better traction you get...
Scott
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
C
Boosted Boss 302 HP/TQ
  • coltoncaskey12
  • May 24, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech May 24, 2026
coltoncaskey12
C
