Sway bar bushing help
wmorris132
I have a 95 Cobra, what sway bar bushing and endlink size do I need? I am also considering the Ford "B" springs, any thoughts on these and strut/shock recommendations? KYB's are cheap but are they any good? Thanks in advance.
If Cobras are like GT's, your best bet is to physically measure your current anti-sway bar so you get the correct bushings. If you dont have a Vernier caliper, you can tighten a crescent wrench around the bar and then use a ruler to measure the distance across the crescent wrench's jaws.
Cant help with those other suspension components.
Good luck.
