swaybar question
speedfreakzx9r
i took my front swaybar off awhile ago and have lost all my bushings to put it back on. i went to order new ones but they said the factory installed different sizes.so my question is how do i measure it to figure out what size i have.
You can use a large micrometer to get is exactly. Ford uses some measurements in inches and in milimeters. It is a PITA trying to get bushings.
Supposedly in 94-95 Mustang GT's used a 30mm sway bar, and 94-95 Cobras used a 25mm sway bar. V6's came with a 27mm sway bar.
what he said. Spend the money on the micrometer its well worth it. I bought a few sets trying to find the right size
If you dont have a Vernier caliper, you can also use a crescent wrench and get real close. Close the wrench around the bar. Then remove it and measure the gap between the jaws.
