switch to manifold??
jimc347
77
i have the stage 1 track heat package. it's a 5 spd with i think 373 gears. but the car is mush downstairs but upstairs it's great. i was told to put the street intake on it will not see the track. does anyone have this setup with the track heat? should i just put 4:10 gears in??
the stage 1 cam dot to dot has no prob on the bottom end. like the other guy said, play with your timing if you havent already. I run 14-15. If all else fails I guess you could advance your cam for more low end but thats more of a bandaid covering up the real problem. oh just a thought, how many inch of merc (vaccum) you pulling at idle?
Drew
i bought the car 2 months ago and the heads are tfs track heat upper and lower stage 1 cam. mikes mustangs did the work. he's next to magic mustangs in deer park.
