Switched Power For Fan Controller
stpete
Well-Known Member
Dec 26, 2015
320
151
63
I need switched power for the fan controller I'm installing. It doesn't take much power. It's only a control signal, not the fan power itself. I prefer switched power from under the hood, but I can run something from inside if necessary. Where is the easiest place to pick up switched power?
Switches power from what? How are you controlling it? Just vehicle on power?
If so, you can tap power off the low coolant sensor plug in front drivers side, or another way if you have an LX is to install a GT headlight switch and use the fog lamps as power on.
Both methods should only be used to trigger a relay or controller. No high current
Sent from my big ass iPhone 6 using Tapatalk
The following are diagrams courtesy of Tmoss & Stang&2birds
Pick a solid red wire from the diagram – any one of them…
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring; http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
94-95 Mustang wiring diagrams
http://www.veryuseful.com/mustang/tech/engine/#95-95Diagrams
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Ignition switch wiring
O2 sensor wiring harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangO2Harness.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
Mustang 5.0 Lights and Radio schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/mustangFoxLights-Radio_diag.gif
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
T5 Cutaway showing T5 internal parts
http://www.veryuseful.com/mustang/tech/engine/images/5_Speed_Cutaway_Illustrated.jpg
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Ford_Injector_Guide.jpg
Convertible top motor wiring http://www.veryuseful.com/mustang/tech/engine/images/mustang88VertTopMotorCkt.gif
Engine mounted fuel injector harness
http://www.veryuseful.com/mustang/tech/engine/images/mustangEngineHarness.gif
Location of the TPS, IAB, and the 10-pin connectors on a 5.0, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/TPS_IAB_Pic.jpg
Starter circuit
http://forums.stangnet.com/attachment.php?attachmentid=21328&d=1080916057
Thanks for all the info. I've temporarily decided to upgrade to a mechanical fan. I'll save this info as I plan to go back to an electric fan in the future.
