I decided to switch to ARP head studs since I will be running, eventually, a 150 shot of N20. I've searched here but the threads I came across talk about proper torque for head studs. So my ?s are below. I have the ARP head studs (7/16")- P/N 254-4401 and will be installed on AFR165 heads in a 95Cobra. I called ARP but they are closed.
1. How many times should I cycle the head stud nuts after the initial installation sequence? The ARP instructions did not say but I figured it should be done because I had to do it with their bolts.
2. How long should I wait between each cycle?
3. Should I put the thread sealant on the block threads or the stud threads or does it even matter?
4. ARP says 65 for aluminum heads and 70 otherwise but I plan to go with 70 or 75. Is this good for nitrous or the heads itself?
Thanks
Al
Thanks
Al
