Engine Oil on water pump bolts
bn536
63
Stuart, Fl
Hey, all. Replacing water pump in 89 GT. The two long bolts, not studs, are covered in oil upon removal. No obvious oil leaks from motor. No signs of coolant/oil mix. Should I just apply a dab of thread sealant and continue install, or is this a concern where I should consider tearing down further to re-seal timing cover? Thanks!
