What are they symptoms of a bad TPS sensor??
My idle is rough.....well rougher than normal. I checked for vacuum leaks and found nothing. I have already replaced the IAC valve.
The idle acts like I am running a huge cam. It has crane 1.7 roller rockers and some larger looking than stock springs.
I am pretty sure that even if there was a cam installed it would not be this bad. What should the voltage be on the TPS and how is the best way to check??
Thanks
Thanks
