Synthetic Differential fluid need Friction Modifier?
Actually, a lot of the synthetic gear lubes profess to have friction modifier built into the gear lube. It goes brand by brand and weight by weight (in the synthetic brand I run, 75-90 has FM but 85-140 does not).
Even if you contact the fluid manufacturer, it's no biggie if you are not happy without the modifier - your rear would bite too hard (not enough differentiating) so you could add FM down the road. It's only about 4 oz of juice.
Good luck.
