I already use Amsoil Full Synthetic (and their filter) for oil. Now I am looking for full synthetics for my tranny and rear end. Any suggestions on brand (and order location)?? Thanks.
it already has mobilie 1 synthetic for both.. Plus i don't think tremec likes you to use synthetic in their tranny even though ford puts it in there.Romeo46LV8 said:I already use Amsoil Full Synthetic (and their filter) for oil. Now I am looking for full synthetics for my tranny and rear end. Any suggestions on brand (and order location)?? Thanks.![]()
I went with royal purple after I welded my axle tubes a couple weeks ago. The stuff that was in there from the factory was scary!!!BLUE03GT said:why dont you go ahead and use Amsoil for your rear-end as well... they are supposed to be the best anyhow... i was gonna go with Amsoil after my gear swap but couldnt come by it over the weekend and got inpatient so i went with Royal Purple.. just as good in my opinion
Turbo92PGT said:im probably gonna put in just regular oil in my rear end when i swap my gears. I haven't decided though. I run maxlife full synthetic in my engine and a k&n oil filter. Is there an advantage to welding your axle tubes or whatever?
Rocketman said:I went with royal purple after I welded my axle tubes a couple weeks ago. The stuff that was in there from the factory was scary!!!
run conventional oil for 100,000 miles and then take the intake assembly off the motor.. then compare with synthetic after 100,000 miles. Let us know which looks clean. Not necessarily better for tranny (especially tremec) or rear end, but for the motor I don't think there are any arguments against the statement that synthetic's characteristics are better.GT JAY said:Personally, I'm NOT sold on the whole Synthetic is better than conventional oil thing. But that's just me.
Read the bottle, it says "Synthetic 5w-20... Amsoil, the first in synthetics." If it was synthetic blend, it would say synthetic blend on it like the motorcraft stuff. Plus, it wouldn't be 6 bucks a quart.JMM said:FYI: The Amsoil 5w-20 in the XL-7500 series is NOT a full synthetic. It is a semi-synthetic same as Motorcraft 5w-20.
wms004 said:run conventional oil for 100,000 miles and then take the intake assembly off the motor.. then compare with synthetic after 100,000 miles. Let us know which looks clean. Not necessarily better for tranny (especially tremec) or rear end, but for the motor I don't think there are any arguments against the statement that synthetic's characteristics are better.
wms004 said:Read the bottle, it says "Synthetic 5w-20... Amsoil, the first in synthetics." If it was synthetic blend, it would say synthetic blend on it like the motorcraft stuff. Plus, it wouldn't be 6 bucks a quart.
GT JAY said:My dad's uncle has a 64 Dodge Polara 383 4bbl with over 350,000 miles on it. He's the origional owner. Other than 3 Valve jobs, the rest of the engine has NEVER BEEN APART! He's only ever used straight 30w in it from day 1. I'd say that's proof in itself right there. Yes new engines may be a little different than the ones built a while back, but as long as you change your oil religiously ever 3,000 miles like he does, you should be o.k. WITHOUT SYNTHETICS!
I'll stick with 5w20 Valvoline myself.
btolenti said:Yes but how 'clean' is the inside of his engine?
Plus I can go 5 or 6000 miles between oil changes with synthetic, almost twice that of old dino oil....
I have an original 239 y-block in my 54 f-100 and it only saw dino oil, but then again, the inside is riddled with gunk.....even though it still runs great.
about how superior Synthetic oil is.
