t-3650
tag4car
Birmingham AL
Hey guys,
tonight i was going out to eat and about 10min after i left my house on a cold engine i noticed smoke coming from under the car at a stoplight, i made it to a parking lot where i could look under and i have a huge splat the color of used oil about 2 inches into the straight part of my X coming from the headers, or right even with the transmission reverse switch is. any how it smells like trans fluid burning (plastic) and when i got home i jacked it up and started cleaning this bright red almost like new trans fluid off of my pipes and trans, i drove it for a few minutes and checked under again, no new fluid there. about 1 week ago i put a bottle of lucas trans treatment in through the shifter box (tri-ax) and that made it shift alot smoother.
ideas???
joey
Check and make sure either the drain or fill plug didnt come loose and spill a little fluid. Id also check and make sure that the seal didnt break on the shifter base where you added the Lucas.
pic of area, that's my d.e.i wrap behind the splat
