  • SN95 4.6L Mustang Tech
T-45 Problem, Need Help!
  • Thread starter Thread starter cooter_11
  • Start date Start date Dec 8, 2005
C
cooter_11
138
GA
Dec 8, 2005
  • Dec 8, 2005
I was recently drag racing at the local dragstrip, and on my last run when I shifted from first to second (not powershifting), I lost second. I finished the run in 3rd, and came back in the turn around lane in third as well. When I stopped for the timeslip, I put it into first, where it is currently stuck. It feels very loose when the shifter is in the first and second gear positions, but when I put it into third, fourth, fifth, and reverse, I can feel it go into gear. It basically stuck in first, and when I go to shift into other gears, it binds because it is in 2 gears at one time. I pretty much narrowed it down to a linkage problem just by that scenario.
My question is, what are some common problems with the T-45's? Do the linkages bend or break? I know it is possible, and I'm not ruling out anything so if you have any ideas that you think will be helpful, please voice your mind.
I plan on taking the trans out this weekend and taking it apart to inspect it. Do you have any tips on taking it apart as in what to look for in terms of wear indications and just generally problems to look for? I've already taken the Steeda Tri-ax out just to make sure something with it didn't go wrong, which wasn't the case.
I really do appreciate the help. Prior to that run I made my personal best pass of 8.71 in the 8th.
ThrashN
11
Chambersburg, PA
Dec 8, 2005
  • Dec 8, 2005
Broken Shift fork. I have a good PDF file that goes through rebuilding them at work. I can send it to you tomorrow.
Built98GT
211
OKC
Dec 8, 2005
  • Dec 8, 2005
The linkage would be my guess.Why you have the tranny out you might as well drop the cash and throw in a TKO.IMO
C
cooter_11
138
GA
Dec 8, 2005
  • Dec 8, 2005
Def. would appreciate the PDF's!! A TKO would be sweet, but the funds just aren't there my friend. I'm thinking about having my current transmission cryogenically frozen though. I know that would help drastically with the strength of the tranny.
C
cooter_11
138
GA
Dec 8, 2005
  • Dec 8, 2005
Definetly would appreciate the PDF's! As for the TKO, the funds don't support that, but it would be nice.
Turbo92PGT
746
Auburn Washington
Dec 8, 2005
  • Dec 8, 2005
Ya you broke your 1st/2nd gear shift fork. They're crap lol. I broke my third gear one. It was stuck in 3rd I had to start out in third up hill lol. Poor stock clutch. 400 bucks around here for a rebuild. I would like the PDF as well for when mine breaks again lol. Not sure about the cryo treating. i've heard of it but i have no idea where to get it done or anything like that or how much it costs for such a thing. Good luck.
D
david l gary
104
Millsap Texas
Dec 8, 2005
  • Dec 8, 2005
t-45
The first ones had a weak shift fork design. The replacements are much heavier.
:SNSign: By the way, I could use the PDF also. I have a complete rebuild kit for mine.
blackink00
I missed a shift & stole Curt's money.
Mar 30, 2005
545
Tempe, AZ
Dec 8, 2005
  • Dec 8, 2005
trannies are a pain to rebuild and you should have a pro do it or else there could be bigger problems if something is a bit off. i broke a fork in mine (as well as some other stuff). just do yourself a favor and replace with a TKO 500/600 and never worry about it again.
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
1965 289 xmission
  • sctang
  • Nov 15, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 30, 2025
Mcmahst
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
