I've decided to rebuild a t-45. It's been pulled apart and cleaned, but now for the interesting part ASSEMBLY!
I've started with the main shaft and the second gear. it seems the logical spot since I have a 3rd gear on order and can't start on that. I added the 1st/2nd sychro setup, but that's where i'm unsure of how things are supposed to work.
How much is the 1st/2nd sychro ring supposed to move from side to side?
I added the synchro blocker trust washer and the retaining ring, and it can't move much at all. It just doesn't seem right. The sychro inserts look to always be causing engagement of the gear.
I think it the sychro hub should sit futher towards the end of the shaft to give the ring more room to move before the inserts hit and engage the gear, but if I do that, there isn't enough room to get the retaining ring on!
Where should the hub be positioned?
Thanks for the help!
I've started with the main shaft and the second gear. it seems the logical spot since I have a 3rd gear on order and can't start on that. I added the 1st/2nd sychro setup, but that's where i'm unsure of how things are supposed to work. How much is the 1st/2nd sychro ring supposed to move from side to side?
Wondering though, did you buy a rebuild kit or what? My friend offered me his T45 for free and I'm thinking about rebuilding on a weekend or something and selling it for some extra cash haha.
