T-5 behind 351 Cleveland in 70 'Stang questions
chepsk8
2,203
Easton, PA
Asking for a freind who has a customer's car.
1970 Mustang
351 Cleveland Motor (not sure if original)
T-5 trans
Problem: Massive clutch slip
Questions:
1. Can the standard bellhousing be used?
2. Is there a difference in input shaft lengths and tgransmission positions between the top-loader and T-5
3. Will the Throwout bearing hit the snout of the T-5, not allowing full clutch release?
any other ideas for the slip much appreciated.
Hope to hear from this smart crew ASAP!:nice:
thanks!
Dan
What "standard" bellhousing is being used? The T5 bellhousing will fit and have the right spacing. What is the rest of the setup? The throwout bearing, fork and clutch cable with the T5 from a Fox Mustang should work fine.
We swapped a t5 in for a toploader. We used stock mechanical linkage, stock bellhousing, stock clutch, stock pressure plate, stock throwout bearing. The only thing we did was add the spacer plate from cal pony cars. Everything else was stock toploader stuff.
Stock cleveland bell just needs the spacer plate.
Slipping clutch could be that the mech linkage is hung up on something? What clutch are they using?
Can you give specifics on the spacer plate, and a good place and part number to order?
Many thanks for the info, as with your input the problem has been identified as needing the plate.
