R rice_killer New Member Mar 10, 2004 4 0 1 Mar 7, 2013 #1 Mar 7, 2013 #1 Hey Guys im doing a t-5 conversion on my 67 cougar? My question is what do I do about the speedo cable? Do they make one to go from t5 to my 67? Im confused thanks.
Fstbk Member Sep 7, 2010 215 2 19 Mar 7, 2013 #2 Mar 7, 2013 #2 You just remove that electronic sender that the T5 has (Unless its to new to have one) and then re-use the gear that you had from your C4.
woodsnake 15 Year Member Jan 16, 2007 1,352 15 69 Hicksville, NY Mar 7, 2013 #3 Mar 7, 2013 #3 Come on over to mercurycougar.net...Lots of Cougar's over there!
R rice_killer New Member Mar 10, 2004 4 0 1 Mar 7, 2013 #4 Mar 7, 2013 #4 Thanks I wasnt sure if I could use the 67 cable or not... Thanks
2 2+2GT 10 Year Member Apr 25, 2009 3,333 10 79 Southeastern Pennsylvania Mar 10, 2013 #5 Mar 10, 2013 #5 The T5 uses the same cable as the auto trans and 3-speed manual.
rbohm Founding Member Apr 12, 2002 6,698 550 204 tucson,az Mar 10, 2013 #6 Mar 10, 2013 #6 be aware though, on which side your cable goes in now, and what side it goes in on the T5. if they are different you need a different driven gear.
chris66dad Member Dec 19, 2008 167 0 17 Benicia California Mar 11, 2013 #7 Mar 11, 2013 #7 My 3 speed cable and speedo gear worked fine on my T5 (1989)
zookeeper Founding Member Aug 25, 2001 3,415 63 109 Rogue River, Oregon Mar 11, 2013 #8 Mar 11, 2013 #8 Same here. My '68 C4 speedo cable (gear and all) slipped right into the '89 T5 trans with no drama at all.
