t-5 experts come!
  • Thread starter Thread starter 5.0fox
  • Start date Start date Nov 13, 2004
5.0fox
410
buckley/enumclaw wa
Nov 13, 2004
  • Nov 13, 2004
Can i use the 4th gear and cluster gear out of an 87 t-5 in a 91 t-5? also what are some companies that sell t-5 parts?
Thx in advance
N
Notched
113
  • Nov 13, 2004
yes u shoul dbe able to use parts from both t-5's interchangeably...
http://drivetrain.com/borgwarnerT5.html
http://www.hanlonmotorsports.com/
there are 2 sites i just googled for real fast, that should be able to help
good luck
wyominghotwheel
156
Insanemustangs
Nov 13, 2004
  • Nov 13, 2004
should be fine........also, just do an google search for t-5 rebuild kit's if you need parts.........hotwheels of turborides
5.0 Nostalgia
904
CT
Nov 13, 2004
  • Nov 13, 2004
Yeah. They will work.
D&D Performance has the rebuild kits cheap. They also sell the gears.
Mustang5L5
Mod Dude
Feb 18, 2001
43,368
18,115
224
Massachusetts
Nov 13, 2004
  • Nov 13, 2004
C'mon guys, you missed this.
There is no 4th gear in a T-5. 4th gear is achieved by joining the input and output shaft together for a 1:1 ratio.
If you use the counter gear from the 87 T-5, you'll need the matching speed gears for 2nd and 3rd. The gear ratios are different and the 85-89 ratios will not interchange with 90-93 ratios.
Synchros, sliders and shift forks will interchange fine, it's the gears that are the problem. 5th gears and 3.37 1sts are the same, but if you swap the counter gear from the 87 trans to the 91 trans, you'll need to use the '87's 2nd and 3rd as well
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Nov 14, 2004
  • Nov 14, 2004
Nice catch. The gears have a different tooth count between those two years due to the better alloy gear design in the newer transmissions.
D
Daggar
3,902
  • Nov 14, 2004
Well at least we now know of at least 2 folks who HAVE actually looked inside of a T-5.
Funanin
356
Horsham, Pennsylvania
Nov 14, 2004
  • Nov 14, 2004
u dont have to look inside to know the gear ratios are different in the different production years of the T5. The T5-Z has even another set of gears different from the 2 already stated.
5.0fox
410
buckley/enumclaw wa
Nov 20, 2004
  • Nov 20, 2004
well on the borg warner tags they say they are years 86 and 90. but i just need to use the 2nd gear form the 91 in the 87. is this possible? i counted the teath and both have 31 so is the overall size of the gears different? help guys!
also i dont need to swap 4th gears and cluster anymore i just need to put the 91 2nd gear in the 87
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Nov 20, 2004
#10
  • Nov 20, 2004
  • #10
If the tooth counts are the same (original & replacement) for 2nd and 3rd gear, then they should interchange......
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 20, 2004
#11
  • Nov 20, 2004
  • #11
See http://www.ttcautomotive.com/English/onlineorder/product.asp to download a FREE service manual for T5 or Tremec 3550
You will need the Adobe Acrobat viewer which is also a free download – http://www.adobe.com/products/acrobat/readstep2.html
See http://www.hanlonmotorsports.com/ or http://www.ddperformance.com/index2.htm for parts
A T5 rebuild kit with syncros, bearings and other small parts costs about $160. It does not include any gears or shafts.
http://cartapes.com also has a video on how to rebuild your T5 or Tremec. It costs less than $20, and is worth every penny of it.
5.0fox
410
buckley/enumclaw wa
Nov 20, 2004
#12
  • Nov 20, 2004
  • #12
do the gears from the 91 have a coarser pitch then the 87 gears?
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
C
Drivetrain TV cable replacement--aftermarket or search other models?
  • chazmanaz
  • Dec 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
AeroCoupe
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
