Can i use the 4th gear and cluster gear out of an 87 t-5 in a 91 t-5? also what are some companies that sell t-5 parts?
Thx in advance
Thx in advance
5.0fox said:Can i use the 4th gear and cluster gear out of an 87 t-5 in a 91 t-5?
Mustang5L5 said:C'mon guys, you missed this.
There is no 4th gear in a T-5. 4th gear is achieved by joining the input and output shaft together for a 1:1 ratio.
If you use the counter gear from the 87 T-5, you'll need the matching speed gears for 2nd and 3rd. The gear ratios are different and the 85-89 ratios will not interchange with 90-93 ratios.
Synchros, sliders and shift forks will interchange fine, it's the gears that are the problem. 5th gears and 3.37 1sts are the same, but if you swap the counter gear from the 87 trans to the 91 trans, you'll need to use the '87's 2nd and 3rd as well
