T-5 Filter?
  • Thread starter Thread starter AZNEAL311
  • Start date Start date Sep 20, 2006
AZNEAL311
85
Phoenix
Sep 20, 2006
  • Sep 20, 2006
I am getting ready to change the fluid in my rear end and tranny. I was wondering if the T-5 uses some type of filter. I checked at the Checker Auto and they could not say if it does or doesnt. All they could say was they didnt have one. The Chilton manual only says something about a tranny filter under auto's, so my guess is there is no filter but i just want to make sure before i get under there and find a filter while my car is down or even worse find out theres one a month down the road and i didnt change it. Also why did they not put a dip stick tube on the T-5s? Thanks for the help.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Sep 20, 2006
  • Sep 20, 2006
MT's are really easy to drain fill.
You need a 3/8" socket and that is all. Both plugs are on the pass (?) side. Remove the fill plug first because it'll be useless to drain the fluid if you can't put any back in.
Then pull the drain.
Use a garden hose to fill from the engine bay. No filters needed, just ATF.
AZNEAL311
85
Phoenix
Sep 20, 2006
  • Sep 20, 2006
Thx, from what ive read in the forums and Chilton it seems to be pretty easy and straight forward. I just wanted to make sure there wasnt a filter. I was pretty sure there wasnt just figured better safe than sorry.
FORCED2DV8
458
Grand Rapids MI
Sep 20, 2006
  • Sep 20, 2006
Make sure to use ATF when refilling, other than that its straigh forward
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
D
Is this a fuel filter?
  • Dutch74
  • Oct 2, 2025
1974 - 1978 Mustang II Talk & Tech Oct 21, 2025
welder4956
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Engine 8.2 oil filters whos still making decent ones?
  • rednotch
  • Oct 24, 2024
Fox 5.0 Mustang Tech Oct 26, 2024
rednotch
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
