t-5 input shaft trouble
  • Thread starter Thread starter stickman5.0
  • Start date Start date May 25, 2008
stickman5.0
11
Anchorage, Ak
May 25, 2008
  • May 25, 2008
So here is my problem. I am almost have completed my t-5 rebuild, and now its time to add in the shims for the input shaft. The input shaft and bearing retainer spins until I started to tighten up the bolts then the input siezes up. Also the gap around the bearing retainer and the input shaft doesn't seem to be even. The bearing retainer is straight and sits flat on the case with the input shaft removed. is it possible that with the race installed with the shims its not seated flat in the bearing retainer, thus when its tighted up making the gap messed up? Any tips will be helpful. Thanks
Fett
766
  • May 25, 2008
Sorry....wrong thread.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
May 25, 2008
  • May 25, 2008
Pictures would be great in this case, so we could see what you are talking about exactly. But right away I'm gonna say the obvious, make sure your not leaving any debris in the assembly that could be throwing the race off-axis. Also, when its all assembled, it shouldn't be so tight that its hard to turn. I don't remember the specs for end play, but you don't want it locked down.
Mustang5L5
Mod Dude
Feb 18, 2001
43,349
18,084
224
Massachusetts
May 25, 2008
  • May 25, 2008
Test fit the race in the retainer before you install. In fact, i usually put the race in the retainer and then lower it down on the bearing.
Also, the first time you instlal, do it without any shims. Then measure endplay and shim accordingly
stickman5.0
11
Anchorage, Ak
May 26, 2008
  • May 26, 2008
I got to mess with the tranny today, and the bearing retainer and race are square. After playing around with the input shaft and bearing retainer today, I think the alinement is ok. But now I wonder if the drag on the input shaft is normal. I cant really spin the input shaft by hand. But if I a pair of plyers i can spin it fairly easily. should the shaft be able to be spun by hand? The output shaft spins normally
Mustang5L5
Mod Dude
Feb 18, 2001
43,349
18,084
224
Massachusetts
May 26, 2008
  • May 26, 2008
it should spin by hand
5.0luver
  • May 26, 2008
input shaft not spinning
Did you happen to change any of the gears and/or cluster shaft during the rebuild. Ran into same problem one time and fought it for hours. Come to find out the 3rd the company sent me had a different number of teeth on it to go with the cluster gear they had sent to replace also. Count the teeth on your gears and make sure its the correct number. hope this helps
stickman5.0
11
Anchorage, Ak
May 26, 2008
  • May 26, 2008
Ya that actually happend to me also, they sent me third gear had an exrta tooth. That was rather interesting. Well about the drag on the input, I rebuilt almost the whole main shaft. As it is right now there isn't a really that much oil in it. Also, all the gears and input spin freely without the bearing retainer. Its almost like there is too much preload maybe.
stickman5.0
11
Anchorage, Ak
May 28, 2008
  • May 28, 2008
Well, I took the tranny apart today. Then I found that second gear had an extra tooth. I need to locate a new second gear then I will put the tranny back together. I think I found the problem. Thanks guys for all your help. I'll let you know how the rest of the rebuild goes.
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
