T-5 minutia
  • Thread starter Thread starter irish
  • Start date Start date Oct 13, 2007
I
irish
168
Florida
Oct 13, 2007
  • Oct 13, 2007
Hey I crawled under my 88 GT few days ago and realized that the bottom few bolts in the bell were never installed, not the main ones that hold tranny to block but the very lowest 3 bolts that hold all the sheetmetal/spacer between engine/tranny together. I need to know what size these are, possibly they are metric? I could just tap them out to a common size but if possible I'd like to just install some bolts and forget about it until the clutch blows up or tranny fails. Anybody know what size or have a detailed blow-up of the tranny showing which bolts go where?
thanks
Matt
I
irish
168
Florida
Oct 14, 2007
  • Oct 14, 2007
bump
TheRedBlur
15
seattle
Oct 14, 2007
  • Oct 14, 2007
they are the same thread as headbolts. When I dropped my motor in, I used some headbolts to help guide the motor/tranny together when I was lowering it. It was helpful because they are longer, but the thread is the same. I suppose I could take a headbolt to work with me tomorrow and check the thread pitch/diameter. Use grade 8 btw.
I
irish
168
Florida
Oct 15, 2007
  • Oct 15, 2007
Hrmm I am pretty sure they are smaller than headbolts, I was thinking that the main bellhousing to block bolts were that size, and the bottom three smaller, I will look tomorrow as I have spare headbolts around here.
TheRedBlur
15
seattle
Oct 15, 2007
  • Oct 15, 2007
oh yeah, those ones..
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Oct 15, 2007
  • Oct 15, 2007
Uhh...mine are missing too. I thought I lost them, but I put everything in a bag one bolt at a time. I am pretty sure they are supposed to be empty. I think I had one in there so that is all I used.
bullitstang1313
713
Indianapolis / Columbus, Indiana
Oct 15, 2007
  • Oct 15, 2007
If you are talking about the small bolts that bolt the backing plate to the bottom of the bell housing, I don't have any in mine right now either. I don't think they are that important.
TheRedBlur
15
seattle
Oct 23, 2007
  • Oct 23, 2007
try a valvecover bolt, they might be the same pitch and diameter.
blackened88lx
Connecticut
Oct 23, 2007
  • Oct 23, 2007
I just put my tranny in this weekend, so I know exactly what you're talking about. There are only 2, going from the front side of the metal plate back into the bellhousing. My car had both of them. They are pretty small, but I can't tell you what size they are. I wouldn't say they're extremely important, but they might prevent a rattle or something. Sorry I couldn't be of any help.
D
Deleted member 87397
Oct 23, 2007
#10
  • Oct 23, 2007
  • #10
All they do is help to further seal the bellhousing against dirt and debris getting in there and screwing up your cluch and stuff faster than normal. Also without them in there you might get a small rattle, but you'll probably never hear the rattle if your exhaust is loud. I don't remember what size they were when I put my T-5 in cuz I just found some laying around the garage. If you want to shore it up without using the bolts just put a small bead of RTV clear between the block plate and bell and it will seal it against dirt and everything else and will be easy to take off in the future if needed.
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
M
Progress Thread mkk50's Progress Thread
  • mkk50
  • Aug 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 22, 2025
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
M
  • mnky99
  • Sep 5, 2025
mnky99
M
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
