It depends on the rpms you're turning. I have a Liberty Pro-shifted TKO in my stang. The faceplated units do hold up alot better on the street. The standard pro-shift will deteriorate with use due to burrs on the the inside of the sliders and the Pro-rings. (been there, done that) A pro-shifted trans never grinds (except reverse), they Klang. Really loud and really harsh. To try to describe it, the shifting effort is totally effortless at all times but when you pull the gear, it's almost like someone is smacking your floorboard with a 3 lb mini-sledge. If you shift it at a really, really low lugging rpm, they're quiet. If you aren't looking to powershift at 7,200 rpms and up, I'd stay away from it. At 7,800 rpm powershifts, they're perfectly smooth and definately worth it.
