T-5 question
  • Thread starter Thread starter GTPor50
  • Start date Start date Jun 6, 2005
G
GTPor50
Circleville, Ohio
Jun 6, 2005
  • Jun 6, 2005
OK...my 89 gt is leaking tranny fluid. I crawled under to see where it was coming from. What is the thing going into the trans on the top drivers side? I was thinking the speedo gear?? I think thats where it is leaking from, but I am not sure. Since that is at the top of the trans. Should that gears just be able to pull out? How is it held in? Thanks
Eric
Curse
791
El Paso, TX
Jun 6, 2005
  • Jun 6, 2005
If it is the speedo gear, there should a bolt holding the speedo gear in. Mine was leaking from there too, I just tightened(<-- is that a word?) up the bolt and the leak was gone.
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
Jun 6, 2005
  • Jun 6, 2005
Speedo gear is on the side of the trans and has a "C" clip with bolt that holds it in. Top is a netrual safety switch.
MAC'n89Blckstng
1,012
NJ
Jun 6, 2005
  • Jun 6, 2005
Mine leaks like a siv from the output shaft seal (where the driveshaft goes into the trans, I'd like to change it but I cant loosen the driveshaft bolts, and the fluid leaks right onto the x-pipe and smokes like crazy so now I have a nasty layer of tranny fluid on the back of my car. Not good. I need a new tranny anyways, blew third out of her a couple of weeks ago. Anybody got a T-5 for cheap?
J
jmd2914
937
Napa, California
Jun 6, 2005
  • Jun 6, 2005
mine is leaking too, but i cant see from where, anyone have any ideas on where to check? ( didnt mean to jack your thread, just thought id ask)
Zero_chance
1,244
Maricopa, AZ
Jun 6, 2005
  • Jun 6, 2005
Unrelated but hey Curse, tightened is definitely a word...
As for leaks, speedo gear, either of the two plugs (drain and fill) can be leaking if there was no sealant on the threads, where the driveshaft enters the tranny.... Also be sure its tranny fluid and nnot oil from the rear intake seal. My tranny looked like it was leaking severely but it was actually oil dripping down on the bellhousing and then being blown back onto the tranny where it dripped down everywhere. But then again my leak was so bad my check oil light would be on every 500 miles or so.
Curse
791
El Paso, TX
Jun 6, 2005
  • Jun 6, 2005
I thought so, just didn't sound right in my head.
silverstripes
81
monroe, LA
Jun 6, 2005
  • Jun 6, 2005
No at the top of the trans on the drivers side the switch with two wires coming out of it is the overdrive/5th gear switch. Tells the computer that the car is in overdrive for fuel mileage and timing.
Check my sig. for your T-5 needs! thanks.
silverstripes
81
monroe, LA
Jun 6, 2005
  • Jun 6, 2005
Oh yeah if you remove the switch to reseal it be careful not to lose the small metal pin in the hole. Usually it stays in the case but just be careful it doesn't fall out. Hope this helps .
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
